Windscreen washer not spraying
Car  FRS
Alright folks been like this for a while the tank ran dry so filled it up with screenwash and never worked since, can hear the motor running but there is no water coming through, had the pipes off blowing into them but no luck!
Same happened to me. In plug pipes from the pump. See if it sprays out. If it does. Go further down unplug pipe from jets. See if it spray out. On mine was just blocked jets at the end. Which was an way replacement.
