It can be done, you'll need to take a spur off the rear speakers and need an amp with a high pass filter, that or a stand alone one for the feed to the amp. Then the rest of the wiring is as per any other system.
Not sure exactly what you want us to say. You can either take it off of the rear speakers or run cable from behind the dash but the end result will be the same with the head unit not having a channel for a sub seperate you will still be using a feed from the speakers on the amp input.
You'll need to get a Phono lead, with bare wires at one end and phono's at the other, then wire this into the back speaker cables (As they're the most accessable) Then you'd get phono's from your head unit in a sense.
I'm with Mike tbh. I would personally get a new headunit, taking a spur off a factory one rather than having a dedicated RCA output is a bit heath robinson.
