Hi All,
Just got back from my first track day at Combe. This is my spec and setup as we ran today.
http://www.cliosport.net/forum/showthread.php?687440-172-Cup-Track-Build
Cant really fault the road holding and handling but we were getting a fair bit of body roll out on track, which would in turn create scrub and eventually under steer.
When I got the car setup I was shown a diagram explaining that by lowering the front you shift the roll centres by decreasing the angle of the wish bone to ball joint, basically creating more leverage for the engine and body to exert on the damper. Hence by actually lowering the front its created extra body roll. This was noticeable on the corners requiring greater degrees of steering input.
Now I was told that by lifting the wishbone mounts on the subrame by around 40mm, to compensate for the 40mm drop, this would return the roll centres to standard. Now I'm sure I came across something similar on here a while back, and an associated modification, but after a fair bit of searching I still cant find the post/topic.
Can/Has anybody
A) Point me in the right direction
B) Done this mod
or
C) Remedied this issue differently
Sam
Can/Has anybody
B) Done this mod
or
Sam
