Worth getting new centre section?
Car  BMW E46 330i Touring
Right, I've currently got a standard exhaust system with a custom 182-style backbox (passenger-side mounted backbox feeding 2 exit pipes, 182-style).
I ideally want to keep the backbox but upgrade the cat-back to release any small amounts of power there are to be had... is there any point getting a cat to backbox section made up by, say, ProSpeed?
Ah, but will it be worth it if I'm keepng the same backbox? How much restriction is caused i the standard system just between the cat and backbox?
well you have got me there lol, i noticed from having a ss cat back that it revs more freely and seems to be a bit more responsive if that helps
I can recommend the powerflow place on marsh barton for a custom stealth system, dan said it all looked great, cost £200.
All depends on who fits it. Had Powerflow custom stealth 2" cat back system fitted last month at Top Gear Doncaster.
Quality is good, fit is spot-on. Little boomy at low speed/revs, but revs more freely higher up.
Mine seems to have lost a bit of torque low down. And it grumbles/booms a bit when using the torque from say 2-2500rpm whereas it used to be really quiet.
Hopefully re-map from pmurray RS Tuning should smooth out the torque.
