Welshname's Monaco 172
welshname
Yeah, pedal goes very spongey, nothing happens for the first bit of travel and then it's just no feel and poor braking effort.
I will give bleeding them with it running a try, what difference does that actually make though?
welshname
Don't think so. I bled the brakes when I got it as they were cack and when it came to changing the pads and discs etc there was no change, and between fitting the brakes and flushing the fluid there was no change.
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
I haven't a clue but my DCI when I wide tracked it, had bad brakes. About gave up and then the mechanic that I help said start it up and bleed them, sorted it. Guessing it does something with the abs pump.
You did bleed, back left/back right /front left/front right In that order.
rule of thumb when flushing is to start at the furthest away
Got to be air somewhere.
welshname
Yeah, your left and right has me confused though as it's late and I'm tired. It was:
Passenger rear
Drivers rear
Passenger front
Drivers front
And JoeyD I've bled them a total of 3 times now including the fluid flush.
  MK1DTi/vivaro/corsa
Yes that's what I ment, looking at the back of the car, back left, back right ect ;)
He's doing something wrong. You ain't letting the fluid go low when bleeding through? Need the keep it topped up as you go or that WILL get air in.
welshname
Yep been keeping it over full if anything and then letting it bleed through to a good level. But as I've said earlier in the thread, when I got the car under cornering hard the warning light came on for low fluid. Now I don't think it was loosing fluid as such but I'm guessing that whoever fitted the grooved discs and s**t EBC pads did the braided lines and didn't top back up after bleeding, then when the pads got to literally the backing plate the fluid level has dropped enough for the light to come on. Which is why I was worried about air in the ABS but from what I've read I'm not getting the same issues people with that are.
  MK1DTi/vivaro/corsa
Hmm, you couldn't use the old ford KA trick which I was going to suggest.
Bleed brake , push pistOn back in with bleed nipple slacked off, and then pump brakes back up again after tightening nipple.
Saying that, KA servos are f**king shite
welshname
Yeah that's what I'm afraid of...b*****d. When I bled it the first time round I did get a LOT of air from the rear drivers calliper but no where else. Every time since however I've had nothing.
  MK1DTi/vivaro/corsa
LOL don't hide it ;) should of kept the D turbo.
P.s do it with two people.
Keep pedal pressed down when locking the bleed nipple up. Stops it sucking air back in
welshname
LOL! That car was the sheddiest thing in the world, and even that had better brakes. They were warped as s**t too!
This seemed to be a common theme with that car:
George@RTR_Parts
ClioSport Trader
Strange one Rhys. If they was working as they should be you would have good strong brakes with those parts fitted. Try bleeding again and also check the servo side of things, listen for hissing etc
I'll PM you now ref bedding them in mate
welshname
Might take you up on that another time. Dads birthday on Sunday so I won't be free, i'll be giving it a go bleeding them with the engine running on Saturday and then giving them another go at bedding in (just in case they were seriously glazed over).
welshname
Well apparently my brakes are fine and bedded in properly and that's coming from someone who has ran the same setup on a ph1 and a cup and its just me being fussy.
Bit disappointed really as they don't inspire any confidence at all. Will just have to get used to them.
welshname
It's not the bite it's the feel. It's none existent, I have literally no clue as to how close they are to locking or gauge of how much pressure I need to put on the pedal.
I'll get used to it I suppose.
welshname
Well as I suspected there is definitely a problem with the brakes.
Went for a drive earlier and the brakes are "OK". Had a moment with some bellend on the wrong side of the road and had to hit the brakes hard for a second until he realised and moved. When I did this the car pulled a little left as it has been doing (I put this down to the tracking) and then there was a noticeable jolt in the pedal (not abs) and the wheel snapped back to centre. Now for about 10-15 mins after this the brakes were sublime. But after a while of not really braking much they went back to the same, even when getting a LOT of heat in them.
My thoughts are it's possibly a knackered slider on the drivers calliper, so I'll be taking that apart and checking everything over.
Carbonraider
  Raider, 172, the van
Did you change the fluid if so you could of got air in the abs pump and it is maybe this that is causing your problems
