I need to tighten up the bolts that secure the boot lock button housing.. Is it fairly easy to remove the plastic trim panel inside the boot to gain access or is it tricky? I don't want to snap any clips etc. Thanks
Excellent, thanks for that!One bolt in the handle section of the plastic, then the full piece just pops off
To put it back together just pop back on, tighten bolt and apply pressure all over to ensure all clips are secure
Thanks spinksy, I really appreciate that. Very helpful indeed! Regards, Steve
Been meaning to get this job done but haven't had time.. And now the boot lock has jammed, the diamond button won't press in & I can't see if there's any way of releasing the boot from inside? Any ideas..
You would have to follow the instructions from above but from inside your boot mate
So enter your car normally, remove parcel shelf, fold rear seats down to give yourself extra space (remove whatever is in your boot), undo the bolt, pop the cover of and you will be able to see the mechanism infront of you
Fiddle about with it as necessary to get your boot to open (try to imagine which way the bar moves when you press the button normally)
