Megane 225 brakes?
  clio 182
I have searched the Internet but not managed to get a definite answer!
I have been offered a pair of Megane 225 brembos callipers, 182 mounting brackets, braided lines, and 300mm discs for £400! Mintex 1144 pads also, the whole set has covered 3k miles.
I'm on the verge of buying them, I just need to know what part of the callipers will need to be machined so it will fit behind my 15" team dynamic pro race 1.2 alloys ? I will be mounting them onto my standard 280mm discs
Any help, pictures, or diagrams would be much appreciated thanks
Cub.
As said above, what offset TDs? But you will need to use spacers to space your alloys. Between 10 and 16mm I'd imagine.
You'll need to run 280mm discs as I don't think 300mm will get under 15s.
I had some of the edge of the caliper machined in addition to the mounting face described above, but I'd only recommend that if the person who does your machining knows that the hell they are doing.
  e92 330i
They aren't PMS mate, unless they've copied them. They are designed by @NorthloopCup.
You need to clean them regularly :smile:
Oh I see, yep PMS do similar ones i guess then! I guess they look so good its a shame to cover them up!
So whats the advantage of these over standard items?
