AST thread size
neil a
Does anyone know or could they measure the thread diameter and pitch for me please.
I need a rear spring seat and ideally want to avoid the AST lead time , so want to see if the likes of a avo/bc/ gaz seat would fit as a lot easier to get off the shelf.
Im over seas until next week so unable to check myself.
I can if you explain what you need abit better?
Just the diameter of the rear shock where the bottom spring cup is?
yes i need to know the thread size on the bottom of the shock to get a replacement spring cup. It will be either 2.25" or 2.5" , but could also do with the TPI (threads per inch ).
Basically trying to see if the likes of this will fit on the AST thread.
http://www.ebay.co.uk/itm/Coilover-...419?pt=LH_DefaultDomain_3&hash=item43a647e533
Rear springs on the asts are 1.9" or 2" id Neil, so you may be snookered. Thread pitch looks to be 1.75tpi or 2tpi from memory.
Dam there goes that plan will just need to chase up AST or worst case get busy on the lathe at work. I would of thought something like a spring seat should of been a on the shelf service part.
