Anyone got a Mk3 Diesel?
Went to look at a Clio Mk3 (59 Plate) 1.5dci GT 106bhp for the sister tonight and was very impressed but there was one slight thing I'm unsure on
Turned the ignition on (but not started the car) and all lights went out besides the 'Toxic Fume Warning Light', which would stay on continuously
However once you started the engine, it went straight out
Had a look in the manual and it says : "For vehicles equipped with this option, the light comes on when the ignition is switched on then goes out. If it light up continuously contact your RENAULT Dealer as soon as possible, If it flashes, reduce the engine speed until the light stops flashing."
Decided to walk away and do some research on it, but struggling to find anything on it
Thoughts people?
Or even better does someone have a Mk3 Diesel they could try and let me know if it's normal?
Many Thanks
James
My mrs has this exact model we have had the car over 6 months now and no issues. Aslong as it goes off after the car is started it shoukd be ok?
Our light always goes out once car started
Thanks for that!
And it stays on if you leave the ignition on but the car not started? (So key turned so all the lights, radio comes on but engine not running)
Thanks!
Thanks for that!
Thanks!
Yep exactly as you describe mate, mine is 56 plate though so i think pre-face lift to the one your quoting but should be the same.
I assume its normal as never had and issue with it and the light goes out as normal once engine on
That is for cars with diesel particle filters, mine was a 60 plate and didnt have one as far as im aware it wasnt until the mk4 that the clio got them! U never know with Renault tho! If the light isnt on when engine is running then dont worry!
Options were esp, climate control, bluetooth stereo, sat nav, panoramic glass roof.
Cruise control was standard along with cornering lights
Cheers Martin, it's not the Particle Filter, as it's a different light
It's this one here :
The DPF is this one in the bottom right :
Also, when starting yours - did it shake on startup and turning it off? Judt for a second or two
Many Thanks!
James
Isn't that just the U.S. Market?
It's referred to as an engine management light in my manual I'm sure.
Pretty sure mine stays lit till the engine is started.
I don't know, it was in the manual with the Clio that I looked at
I always refer to it as the Engine Management Light, but when I looked in there it said Toxic Fume Filter...so don't know?
Will have to take a look. I know because of California and the hippies, their emissions are quite harsh, but I've not heard of anything like that in the UK cars.
yeah that's just the eml then, nothing to worry about, it lists it as the "toxic fume warning light" but that's obviously just for petrols with a cat/lambda
on yours its used to highlight issues with EGR valve among others, as long as it goes out when the engine starts then that's fine, its the same on all clios
I don't remember mine shaking on start up or shut down but then it was brand new, my old dci 80 does this, its just play in the engine mounts
Quite a few optional extras,
Folding/heated mirrors, sat nav, Bluetooth, sunroof, keyless entry and start, digital climate control, I've got a list on my GT thread, mine had every box ticked iirc still got it just can't remember what's a option and what's not anymore lol
