my first clio P2 iceberg 172
  Nimbus Grey 197
  Nimbus Grey 197
So it's been knocking it's titts off lately with one thing or another broken gearbox mount then managed to sort out the noise from my exhaust on my arb
and still knock knock after I go over a couple of bumps and today after a couple of hours funnily found the culprit
The pin was moving up and down and you can just make out the score on the bolt so got a new one and went for a little test drive and thank god it feels nice and no noise
Finished cleaning it the other day to
I've got some forge hoses that are coming to clean up the bay so when they do I'll get some paint and give the whole bay a nice tidy and picture
  Nimbus Grey 197
My hose fitting was going so well got the rad out everything was going good
Whilst everything was out the way I decided to check my pms air-con delete kit as it was looking a bit bent and took it apart and it was snapped
No pictures of this as I was annoyed and just kept putting the rest of the hose kit on
So went online to get the new pms bracket and found they are away until the new year but not to worry I have just fitted my new diff seal and have also orderd the mass damper kit for my shifter kit but again for the 100000000000000 time this year it will sit like this for a couple more days
  Nimbus Grey 197
And pic of the bracket
I have now ordered a new bracket along with the noise reducer from pms hopefully this one will last over 12 months
  Nimbus Grey 197
right went on a nice big drive today and the car felt great with the new pms damper and decided to give it a clean and another chance to use the camera
  Nimbus Grey 197
right updated spec list also i had missed a bit so here it is longer and longer
handling
powerflex front wishbones and arb
brembo max disks
pagid blue pads
oz f1 wheels
pure motorsport top mount and strut brace kit
camber bolts
gaz gha coilovers front and rear
whiteline anti roll bar
rear camber shims
federal rsr tyres
10mm rear axle spaces
20mm front hub centric spacers
engine
vibra techinc engine and gearbox mount
pure motorsport ac delete
ported inlets
magnecore leads
powerflex torque mount
miltec decat
oreca group a non res exhaust
pure motorsport shifter kit
rs tuner 98ron map
blue forge coolent kit
ph 1 airfilter with powerflow foam filter
forge induction elbow
interior
omp steering wheel and boss
corbeau seats on custom mounts
sparco 4 point harnesses
roll cage
stripped interior and painted boot
kenwood head unit
pov spec door cards
Renault mats
exterior
skoda splitter
non xenon head lights
cup washer blanks
painted front grill
hella supertone horns
cup racer tow eye
cup spoiler
brake ducts
rear wiper delete
  Nimbus Grey 197
quick shot at work the other day I am going snowboarding next week so have been busy getting ready but my new tyres turned up today so after my holiday should be able to get the RSRs back on but other than that is going well
  Nimbus Grey 197
whoop whoop new tyres they are still in the loft at the moment but soon they will be on and when the weather gets better i can use them i do miss them
Jekyll
I can't help but look at your wheels and think that they'd look awesome in fully green!
Nice car buddy, I like what you've done to it. I'm looking at the same seats/harnesses for mine, when I get one. Where did you buy them from?
  Nimbus Grey 197
Yeah there my Winter wheels so I might do a different colour next time and will do the whole wheel lol the seats I actually got 2nd hand but where brand new and you can get them off the corbeau web sight they come with runners and side mounts for 170 I think then harnesses again eBay I was after some for a while and they came up so snatched them
  Nimbus Grey 197
i suppose until show season starts there isn't much that goes on with the clio bar cleaning and more cleaning however today i did clean it and also cleaned up 2 of my other wheels ready for tires some time next week however i did seize the moment today and got some nice shots of the car outside wootton hall.
  Nimbus Grey 197
Right well then this has suddenly got exciting i am about to book my first trackday of the year Donington on the 18th of April so ive got 6 weeks and a list of things to do changing my tyres being one of them
  Nimbus Grey 197
After cutting myself I finally have my tyres on so these will be going on over the next few weeks when I get the car ready for mot and the trsckday in April
  Nimbus Grey 197
so looking into Donington Park on the 18th of April I thought my exhaust might become a bit of an issue so I set about to looking for a suitable DB killer just in case I needed one scourd the internet and only found one which was 00.04mm to big for the hole however Jetex is close and they have this contraption..
This fits perfectly in the whole I have not modified it at all all I am looking to get a nut welded on one of the wholes the drill a whole in my exhaust which will then bolt it in place and the difference from just being on idle and keeping it in place is quite large
  Nimbus Grey 197
right all booked into Donington now and just need to finish my baffle i have been working on the car checking it over for the dreaded MOT so will see how it goes i have raised it up and made it look like a monster truck but hey thats what coilovers are for right few pics of getting it sorted at least i now have my federals on
  Nimbus Grey 197
So managed to get the car ready with no issues
And got there no issues
Then about to go out after lunch and before I even got to the track it was making a noise and now the diff seems to have given up so not happy but did get half a day out of it
  Nimbus Grey 197
Well it's proper fooked now can't even get the box repaired got a couple of pics my circlip is in there somewhere and where it's being flung around it's just broken everything the amount of times its been rebuilt I just don't think I can do it again so decision time ...
  Nimbus Grey 197
so have been a bit busy trying to get different things done and i have. first off i managed to find a replacement gearbox which was painted and looks nice.
  Nimbus Grey 197
at this point my car had been like this for a while now
so i decided to put a new clutch in and glad i did
here is a pic of the old one and you can see how oily the pressure plate is
whilst this was being fitted I got the Mrs busy and started doing something I wanted to do last year.
just need one more cote and my lovely subframe will be painted.. the box is now back in and i am waiting on my shock to return from GAZ which should be soon but for now it looks a bit better without all the jacks all over the place.
  Nimbus Grey 197
not that much has happened to the car but slight update i decided to put my old supersprint stealth back on as i knew this would pass noise at FCS and it only just did at 99db i have got some pictures of the show and some other bits however i don't have them to hand but here is the video
of the track time which i loved and the car as normal loved it to i have however just raised up the back slightly and i think now it feels much better..
however after a long drive yesterday i think i am getting old and am thinking about getting the PMS exhaust so i don't have to worry about noise and to make it a better drive
knew i recognised this from somewhere! i was in the flame red 172 on track at the same time as you, was pooing it as was my first ever time on track didnt realise i was going so slow compared to the other clios haha
  Nimbus Grey 197
Nice one and well done for giving it ago buddy
cheers mate, watching the video you were flying!! got the bug now wanna do a few more and get my confidence up, can you recommend any other good tracks was a bit nervous at combe as there is not really much run off and seen quite a few big crashes there!!
  Nimbus Grey 197
Lol I was advise doing a few full days I did one a combe last year and it was amazing quiet track because of it being an open pit I did donnington recently it was also amazing but broke my car so will be going back to seek revenge
  Nimbus Grey 197
right PMS exhaust ordered and hopefully will be here at the end of the week i have planned to fit it at some point over the next few weeks but will see what happens as i normally cannot wait to get stuff on the car
