Number plates - drilled or stuck?
boultonn
Car  911 GTS
Getting some new plates delivered,
should I get them drilled and screw them on, or stick them on?
I've always preferred stick on as it looks much cleaner. Some double sided tape from halfrauds works a treat :)
I use Velcro strips on mine.
Ever had any problems with them coming off?
Don't think I'll have any need to regularly take them off, although as they're custom plates I might want to remove them cleanly when I sell
Switched from screwed to Velcro this summer, much cleaner and doesn't matter if you don't get the plate dead straight first time. If you have old screw holes get some rubber grommets/bungs and a bit of silicone sealant ...or just stick the Velcro over it!
I too use the velcro coins from Halfords, great to take them off whilst cleaning the car.
Don't stick them on with double sided tape either! I did this on my old car and when it come to remove my private plates it ripped the paint off [emoji88]
100% stuck/ velcro'd.
It bothers me every time i see one that Merc dealers always use 4 silver screws per plate, looks fugly!!
I hate that as well.
Half the time they aren't even straight either.
Top tip!
If using Velcro coins, put the soft Velcro on the car and the harsh hooky bit on the number plate
Otherwise you'll have it eating your microfibres and wash mitts when you clean it
Top tip!
I wondered which to put on the car, and just happened to put the soft ones on, what a stroke of luck
Anyway, thanks for the help chaps, it's looking good (minus the filthy car), had to reposition the back one slightly and it felt like the bumper would pull off before the velcro unstuck so not worried about them falling off!!!
Velcro. I went overboard on the first set of plates I used and nearly ripped the bumper off the car trying to pull them off. You literally need a couple of little strips.
