Spacers 'guide'/info
Hmm, that looks great. Handle okay on that? What ET are the wheels?
The top picture (standard wheels) are 43 offset I think. It handled well with just the bilsteins in that pic.
The williams wheels are et 36 I think. It handles brilliantly imo (a few trackday videos support this). But it's got ASTs, roll centre kit and a whole host of other suspension goodies so not sure how much the spacers have / haven't helped.
Found a better front view to see the stance..
I have 195 tyres on the front and 205 on the rear.
Bloody hell, this hurt my head about offsets.
http://www.cliosport.net/threads/difference-in-et-speedline-turinis-to-172-cup-turninis.551168/
Anyone have a pic where it says the offset on turinis, so i know where to look?
Should be on back of one of the spokes. However I've just seen this which looks as though it's on the outer rim on the rear of the wheel.
Also someone has said on another thread that it is printed in the centre hub of the wheel if they're Speedlines rather than Renaults Speedlines.
Hmm, i'll try again! Thanks though.
Next question would be had anyone fitted 5mm spacers with standard bolts and had issues?
That flamer is ace
Does anyone know what the standard bolt length is? 25mm? Just trying to work out what bolt length to get with the rear spacers, thank you in advance.
Yes mate,im pretty sure you wouldnt need longer bolts for 5mm.but anything bigger i would recommend getting longer bolts.
I do have some longer bolts and a load of bolts if anyone needs some to.
That's good to know as you aren't far away from me :smile: think i will give them a go and see what happens!
ok mate no worries,the longer bolts are for 20mm spacers tho.I dont need them anymore as i have stud conversion.
No problems, have been looking at the stud conversions too, that will have to wait I think
Yep standard bolt size is 26mm BUT even tho these should be ok for 5mm spacers, as I've said before, for such a low cost item it's not worth the risk, just my own opinion, for the 5mm spacers on my car I moved up to 30mm bolts
Oh and that photo of the numbers on the back of the rim of the cup Turini, that's where they are on mine too :up:
When I order the spacers I am going to order new 30mm bolts, I agree because they aren't expensive I don't think it is worth the risk. I am going hubcentric on the front so they will be all good :up:
Right, just ordered 10mm PMS spacers, probably chuck them on the rear and then buy some 10mm fronts in the new year. Still no idea what et my wheels are!
Will 10mm all round look odd?
Wow Chris_Beer that looks great! Never seen a white one before.
I have 20mm spacers on the front which fill the arches perfectly. 20mm on the back will rub with 205's as I found out so currently not using any.
Will wide front spacers increase understeer? You'd think the opposite would result.
