CS_daves 1 dies to save another project
Yeah fair one I wasn't sure how you painted it that's all, and know you've broken a fair few what look to be perfectly good Clio's lol
A black car this age is always going to need some attention. Look forward to how this one turns out :up:
Yeh its straight thats the one thing that was the main thing lol. Its one of them i always on the look out for the perfect shell but its going to cost money i dont want to spend. This can be made as i go. Ive gotta ho with what ive got at some point or ill never get it built.
Diy painting lol
Yeah sorry I just saw the above two photos and jumped to conclusions as it looks like a barn or something and quite a cloudy flat finish after.
But daves later photos show it isnt the case :smile::up:
That's a good smart repair mate, might have to get in touch with your man to tidy mine up when I'm ready to have it done!!
Loving the progress you put in on it, you just get on and do!! I start and give up. Lol
But daves later photos show it isnt the case [emoji2]:up:
Tbf he is coming around to give it a machine polish so alls good lol. Top lad is lee does some real smart top end cars.
It does have marks but there panels that can be swapped its just going to take time on that front.
Yeh i tend to try n keep at it mate as if i dont ill never finish. Im down with the shell tomorrow to give the engine bay a scrub and remove the brake lines ready for abs delete
Spent alittle time down the work today plan was strip down the cup rear beam to swap onto the one on the car.
Remover stub axles and whiteline RARB but couldnt for the life of me find a 11mm spanner was going mad!
Need longer bolts for the stubs as im going to use 10mm spacers
Give the PMS exhaust a wipe over as will be going on this week :-)
Spent alittle more time on the clio.
Swapped the rear beam for s low mile cup one with the cup stub axles also put 10mm 1 deg camber spacers on as i ad them kicking around.Removed the rear brake lines and levaler to swap for the cup lines (ABS delete)
I then fitted the b14s with adjusters and the whiteline RARB i ad a set of stud n nuts from another car i ad so onto some good rear discs only suffering surface rust still need to get some locktight for them. On removal of the rear calipers i could see i needed some rear pads so a small order to ECP grabed oil and filter while i was there in perp for the engine refit.
Gave the calipers a paint and the rear end a clean under the bumper and lights as the spider webs where doing my nut in.
Fitted the scenic shifter just to make sure all is good.
Last thing was bolt the secand hanger for the pms exhaust and the prima racing exhaust mount.
Thats all for now.
Thats all for now.
Dave get that bloody interior cleaned up lol
Will do cant get passenger side too lock and thinking if selling.I the vee I'd rather keep it standard.Will let yall know when I find a set of standards
Well the bonnet has been put in today still need to drill for the areo catches as the bonnet was secand hand i didnt put catches in so need to drill to make them fit
What can i use to remove the sticky tabs from old number plates?
A tar remover should sort that dave
Autoglym in halfrauds if only option
I'm sure there's sticky stuff remover you can buy if the tar stuff is no good.
If it's still got the spongey stuff on get a hair dryer on it and carefully peel as you heat. Getting the glue off should be easy then.
Are you sure they're not holding the bumper together though? Who the hell uses that many to mount a bloody number plate??
I know lol i only want 2 velcro pads
At last i got around to removing the slam panel and drilling for the areo catches all went to plan so pleased the bonnets finally on.
Got a set of 2118s from @B00mer as im doing him a favor n stripping down his cup for him its 100% the last breaker ill do so im not advertising items via cs due to the trader fee and no money will be mine at the end of the day. They have been plasty dipped by christ that stuffs hard to remove.
1 wheel has curb rash so the set will be poweder coated at some point.
