Mr Plums Progress.. Clio 182 Turbo!
  RB Clio 182
I noticed that the temperature gage was taking longer to get up to temp so i have just done a coolant change along with a new thermostat and temperature sensor, all is now well :D
Still for sale ;)
cs_dave
West Midlands
robmunns
  Ph1 172
The adaptronic has an inbuilt 4bar map sensor I believe, if you can get to the ecu check and see if there is a pipe coming out of it.
Its usually taken from this bit of the inlet and fed through to the ecu
Map sensors are just left in to plug the hole I think. This is the case on my turbo one and my brothers anyway but I may be wrong
  RB Clio 182
Its usually taken from this bit of the inlet and fed through to the ecu View attachment 174697
Ahh right, yes there is a pipe from the ecu to the inlet, but mine is just below the standard map sensor, so you may be right mate.
OssPoop
Haha brilliant!! Just keep it and say it's still advertised......... when it might not be :laughing:
Worry about the 'have you not had in interest in the car for a while now?' question later!!
