Ph1 'Exclusive' Budget Track Car
vroomtshh
  Seat Ibiza Cupra TDi
About a year ago, I decided I had too much money tied up in my track Leon, and I should replace it with something a little more budget conscious. I've had a few 172's in the past, and they're cheap as chips and pretty good standard around track so it made sense to buy another. FIrst one that came up was an exclusive, and I fancied one that wasn;t blue or silver so it was perfect.
Took it straight from buying it to a tracknight 😂
So now I had a list of things that needed improved. A couple of seized calipers and a dead rear shock to begin with, but other than that, the car was pretty solid. Engine was good and it's not rusty.
vroomtshh
I'd never seen an exclusive before, and 2 days after buying it, I came across this is a car park 2 minutes from my house
And now was time to fit a few new bits. I already had seats and harnesses left over ffrom my Leon, and I bought a set of pure engine mounts, strut brace and top mounts and stud and nut conversion. Got all that fitted up pretty quickly.
Quick release bumper pins I had left over
Harness bar welded in
Air con delete fitted
Small battery under passenger seat
vroomtshh
Brakes were all free'd off, and some high quality £11 ferodo pads fitted (wanted to make sure it all worked before spending money on decent pads)
and off for another trackday. Pretty uneventful. Car felt a lot faster now the brakes were free'd off, but the dead rear shock wasn;t helping things 😂
Luckily this wasnt me
Manage to get a swap for the horrible turbines
And a decent set of suspension
A set of ebay brake ducts, and tow strap
vroomtshh
I think I did approximately 0.1miles on the F1's before I decided I didnt like them, and I got a deal on a very dirty set of Pro race 1.2s, and had them fitted up with a new set of A048s.
I was on the phone to Pure, ordering up a decatted, single silencer exhaust system, and Nick mentioned they had 1 ph1 fibreglass bonnet left in stock and wouldn;t be getting any more 🙈, so thought I better get that too.
Excuse the cutout in the bumper - it wasn;t me 😂
vroomtshh
Made a start tidying up the rear wiring loom
And whipped the dash out to get the last of the sound deadening out.
At this point I was 'done'. It didn;t need anything else, and I hadn;t went too crazy budget wise.
vroomtshh
Then the budget went out the window and I start buying stupid things that the car definitely didnt need 😂
Squeezed in another track day
I decided at this point that a passenger seat was just extra weight that I didn;t need so upgraded to a nicer winged seat
And got some door cards in a group buy on here
New filter for the SM intake
And on - mostly
Spent 5 minutes cleaning some of the PAS fluid off the engine
vroomtshh
Managed to get a deal on a few more fibreglass panels
The bonnet was pretty flappy so I added a middle fixing
And added some speed holes 😂
vroomtshh
Finished off fitting the SM intake
Jumped in on a CSOC scotland rolling road day
Car made decent power, and at this point I ignored it pretty much the whole winter.
vroomtshh
Bought a spare set of wheels as I've always wanted a set
And a Pure shifter (is it even a clio without one)
Thought I'd see if I could cut out a bumper a bit better for the exhaust
Some people might notice thats a ph2 bumper :fearscream: - the horror
Tailgate fitted
New ECU fitted (yes that was a nightmare)
New seat mount fitted
I ran a group buy on here for some Lexan windows
vroomtshh
And at this point - disaster struck. I was taking the car to the paint shop to get the rear end done. Got it out the garage and the alternator belt snapped, and took out the timing belt :angry:
So now, it was either break it, fire in a cheap engine, rebuild the old engine. a ph1 engine with 44k miles and full history came up for sale around the corner from me, so it made it a bit of a no brainer. And what should have been a weekend job of swapping an engine has turned into 5 months of work 😂
New engine
Old one out
I decided that maybe the Pure AC delete was flexing and that allowed the belt to come off, so I got the new uprated version
And thought I may as well get a light flywheel while it was out
And then I made the mistake of painting a few bits to tidy it up
PAS removed
Extra bits removed 😂
Engine built back up
Manifold wrapped
Engine bay gradually getting emptier
Servo painted
I then decided that the engine bay was a bit grubby and it would be as well being painted too 🙈
Single wiper
vroomtshh
ABS delete hoses and poverty spec heater motor in
New suspension arrived after 16 weeks of waiting - You may spot a small problem with it
Phase 2 dash and pod sorted
Rear end back from paint
At this point I'm pretty fed up waiting for Curtis to sort out my suspension so I started buying more suspension parts 😂
And it's going back together
Wishbones welded up
Beam stiffened
Everything powdercoated
Brake hoses getting finished off
vroomtshh
At this point, the old radiator looked a bit scabby
And it made it outside for the first time in a while
And then it was put away ready for mapping
vroomtshh
Yeh the budget has went a little out the window 😂.
I'm up at the CSOC Scotland night on the 3rd July assuming I can get hold of a N/S Ph1 wishbone and it doesn't die during mapping
Djw John
Scotland - South
Cool, I'm considering the 5th of august KH run one and booked a private one for 24th august.
Get the later wishbones for the extra caster.
Coops Mk1
  Lots of Scrap...
ai use the 182 cup wishbones, lots of lovely free caster then!
and as above, lol at 'budget' in the title! looks great though and once bonnet is painted it'll be spot on!
vroomtshh
Awesome build!
Do you still have the Exclusive interior?
No it's long gone
I'll hopefully get a few more in through summer. I don't know why I wrote wishbone when I meant driveshaft. I already have the later wishbones
green
  Hi comp phase 1
Love it! Good luck with the mapping :up::up:
Are you running standard cams and head ?
vroomtshh
Nice work for a "Budget Build" :up:
What radiator is that ?
Its from Pure Motorsport. They do 2 options. A polo radiator chopped about a bit, or this one, a full on custom jobby with ducting etc
  dan's cast offs.
out of curiosity who's braided line kit did you get?
oh and throw a set of cams in and get the pms exhaust manifold :tonguewink:
  LY 220 Trophy+IB PH1
Great build, PMS have had some trade from you haha
Have you drove it without the PAS yet ? I've just removed mine but might be a few more months before it's driving, some say it's pretty heavy without it !
vroomtshh
Mitch from Proline motorsport made me the kit.
That's coming soon 😂
You're not kidding. I think I've put Nick's kids through school. There stuff is just always so well thought out that its hard to beat.
I have driven it, its pretty horrific at slow speeds. I'll most likely be going EPAS sooner or later
The_Pirate
  Golf R
Thats absolutely awesome!
Budget build lol. The funny thing about Clio's is, they are cheap like you say - but f**k me its still plausible to empty your wallet in one sitting!
vroomtshh
how much and are the ends crimped?
There are a few options for pricing depending on exactly what you want. Best thing to do is give Mitch a call, he'll gladly talk you through the options.
The ends are crimped yes
