People with fairly high spec/tuned track or race 1*2s.. Is it worth it? Im not sure if its that my car needs a proper setup or my expectations of the these clios are too high but I feel every step of upgrading and fine tuning never goes the way I think it will.
Currently have strengthened wishbones with camber, bump steer ends, new inners and rack bushes, custom steering column, ast 4100 with 400lb springs + top mounts set to full caster on front. I had the asts on the rear also with 400lbs but they were to low so have put on gaz golds for now 300lb springs with pre load. The asts though were too soft on the rear and that was for road driving, again the golds at 300 were crazy soft, Ive done up the pre load and has helped but they arnt really made for it and bounce around a lot.
My plan is to send off the asts for 100nm rear and 90nm fronts with correct length springs, I have my doubts as to wether this is going to be the right choice (for handling) and again Im going to be expecting a lot more than it may be. Should I just go for it and get the car corner weighted as well? Anyone else modded theirs and not got what they expected or actually made it into something that was above?
Also will add that the couple of things I havnt done is arb bushes and rear beam bushes, the arb bushes are new from about 2016 though..
