NEST vs HIVE - smart thermostats
Danith
  MX5 ND2/220 Trophy
Anyone got experience of these? Presume they're quite common and I'm just 10 years behind, ha.
I can get the Hive for £199 installed or get the NEST and install it myself for a bit more.
I can see that the NEST is a more intuitive and learns your habits etc and also that it detects when you leave the home to turn off. But in a way this kinda puts me off as it's no doubt more data farming by Google?!
What are folk's opinions on the Hive (and nest)?
ta
Ol’ Tarby
  Clio 220 Trophy
I've got Hive and it's bob on. It also does geo location so you can set it to come on and off as you leave. It's also connected to my smart speakers so I can set the temp from any where in the house if I've not got my phone on me.
Can stick the heating on when I wake up without moving from my bed until the house is warm. Love it
Danith
  MX5 ND2/220 Trophy
Ahhhh. Yeah you get an Amazon hub thing with it too. So you just tell that to up the heating and it does it?
TheEvilGiraffe
South East - Essex
Had Hive for a few years.. was installed with new boiler.
Got a load of lamps which is brilliant as you can just put them on and off from the sofa (or anywhere on the planet if you have internet access), set times for them to come on and off, such as at sunrise/sunset.. which is infinitely better than having to adjust timers every month of the year.
Can get plugs, alarm sensors, cameras and all sorts.
I've got my garage door plugged in to a smart plug so I know I can't accidentally open it / no one can jack it.
Danith
  MX5 ND2/220 Trophy
Sold.
I'm ordering the hive. British gas customers get it for 16.50 a month (12 months) fitted and with support. Free Amazon echo dot 3 (smart speaker?) too
Ben
As above, my boiler is also pretty old too. It’s early 2000’s but still works perfectly so I don’t fancy buggering it up with some fancy tech.
TheEvilGiraffe
South East - Essex
Do they work with any boiler? Mine seems to be from the 80’s!
Don't see why not.
All a thermostat does is tell the boiler to switch on or off depending on temperature requirements.
A timer tells the boiler if it is ok to turn on or not depending on the time of day.
A hive/nest/a.n.other is basically both combined.
Ol’ Tarby
  Clio 220 Trophy
Sold.
You got BG boiler cover? I was having mine serviced and the guy did me Hive for 99 quid
Danith
  MX5 ND2/220 Trophy
I've got some cover yeah. It's free with the plan or something. Where did you get the offer? Link on their site?
welshname
Depends on the ecosystem you like. If you're into your Amazon based stuff, then stick with Hive. If you're into the google eco system then nest.
Neither is better than the other to any real degree in my opinion other than I think the nest looks nicer/more modern.
Danith
  MX5 ND2/220 Trophy
yeah I'm just not too keen on the old school thermostat thing I've got in this new house. Old turn dial thingy Hive will do for me I think.
  CBR1000RR Fireblade
Are these really worth the fuss / subscription?
My timer is on constant and the thermo stat is set at 15 degrees and has been for a few years. I never touch it, no need to
Darren61
We went for the 3rd Gen Nest Thermostat and it’s been great so far. Works out your routine and needs on its own pretty much, can set from wherever you are (home or away) it turns off when your devices leave the house.
Looks the part Vs Hive IMO but most likely does pretty much the same thing. We have a modern Vaillant boiler and it already had a basic wireless thermostat which we had wall mounted. So the Nest swapped over straight to that easily, but because the old thermostats just ran off AA batteries, there wasn’t any wiring on the wall to wall mount them. So we ended up buying the stand for each thermostat (2 loops, 1 upstairs and 1 downstairs) and positioned them in better places than the “hallway” where quite often the temp isn’t relative to a room you may be using, especially if it’s near the front door for example.
Downside was having to buy 2 stats, plus 2 stands and installation, easily £500..
Marc.
We have 2 Nest thermostats at home. No different to Hive (my parents run Hive) and the only downside I can see is the cost.
I never need to use it, the self-learning part is really intuitive. Mine are fixed to the wall, rather than on a stand, so didn’t have to pay for those.
Works with my car too, so I can set it to “Home” when I get in the car (if I can’t be arsed to use my phone...)
SC03OTT
  Octavia vRS
Tado is another one to look at although it’s not as good as it was IMO. A lot of the features are now behind a subscription pay wall (geolocation) but I think you can get around that if you use Apple HomeKit. The radiator thermostats are also great to. Like I said, just another one to look at if you’re interested.
Danith
  MX5 ND2/220 Trophy
For 16 quid a month it's got to be better than this. 90s bling
Thrust-Rated
President of the KMAG fan club.
  F31 35d, Berlingo Na
I've got a Worcester so opted for the Wave which is worcestors own smart thermostat. It's just as good as a nest but the nest looks and feels better.
My parents have a nest and it is really good.
The convenience of being able to turn the heating up whilst out the house so you come home to a warm house was enough to sway me to a smart thermostat.
JP83
South Central-Oxfordshire
I think our thermostat is on it's way out, but probably has been for a few years now.
We're on an old oil boiler at home - does anyone else run a smart themrostat with one?
Stay Puft
  Clio 172
Been quoted £240+vat to supply and fit Hive with my old school boiler. Seem an ok price?
realnumber 1
One thing to think about regarding these 2 is that Nest is the only one that supports opentherm. If you have or are looking to get a newer boiler it should work better.
It also makes use of a motion sensor and looks better!
Thrust-Rated
My vote is on nest over hive. They look the b****cks
Danith
  MX5 ND2/220 Trophy
Sounds right if you're not a British gas customer. I think fitting is a doddle though so might be worth self install to save the fee.
Stay Puft
  Clio 172
As my thermostat is so old I think I may need wiring to power it
Danith
  MX5 ND2/220 Trophy
Think they use wires from boiler to attach a transmitter then put the wireless hub thermostat thing in the house anywhere you want.
Stay Puft
  Clio 172
Does anyone know if I can use Nest to control hot water? I have a separate hot water tank in a different cupboard.
Darren61
Just contact Nest direct, they’ll put you in touch with a local, nest authorised installer, and the customer service (IME) is really good
R3k1355
Absolute wetter.
Nest is part of Google, so if you're thinking of any other smart home stuff it will integrate with those, there's quite a few.
Google Home Hub & Hub Max
Nest Hello Doorbell (same as Ring video)
Next CCTV cameras (outdoor and indoor)
Chromecast
Even a smoke detector
