Sunroof or Windscreen leak?
  MK2 PH2 Extreme 1.2
So I went out to the car the other day after it had rained heavily, started driving and strangely my left arm became rather wet. It looks to me like the water is coming from behind the map light and that odd little grill next to it. I assume this is due to either a leaking sunroof or the top of the windscreen leaking? There's no water in the foot wells and the headlining surrounding the area is bone dry. Anyone have any ideas which seal is to blame?
  Clio 172 Merc ML55
More than likely to be the sunroof, pop the interior light out and you'll probably be able to trace the leak back to source
  Renault Clio
Hi did you manage to fix the leak, my wife's car is doing the same, water coming from head liner near sunviser on the drivers side
Sash
  A Yellow One
If it has a sunroof you’ll need to take the glass and frame out and reseal it!
