Wow! That’s an exciting lot of work!Polished the headlights, fitted door speakers, hoovered it out, fitted new mats, bought four new tyres. In with RS Tuners in Leeds first thing Monday morning for new brakes all round, a full service and re-map. Expecting a different animal back![]()
What did you use? I've just picked up a 2004 182 and they are manky!Cleaned the seat belts
View attachment 1475474View attachment 1475475View attachment 1475476
Sent from my ONEPLUS A6013 using Tapatalk
Remove the lower belt fixing bar (T30 torx from memory) pull the belt to it's full extent then use a bulldog clip or similar to stop it retracting. Use a bucket of water with a few scoops of Coop stain remover powder and get as much of the belt in there as you can by putting the bucket up on something. Leave a few hours and rinse, mine came up great and the bucket of water was grim afterwards.What did you use? I've just picked up a 2004 182 and they are manky!
Definitely a PITA doing the belts on these.
Wasn’t happy with my crank pulley’s rubber being perished so ordered a new one, that stopped job completion but should be there tomorrow so will get it finished Friday.
Some numpty had also destroyed the lower plastic timing cover (mind you it’s blumin tight!) and also siliconed the holes in the cam end plugs rather than replacing them.
Timing wasn’t right from prev belt change either as the cam locking tools were certainly not going in.
Lots of noisy bearings on all the idlers and tensioner. Never have known it as car was pretty quiet.
Think I spent more time than anything else trying to remove all the original water pump gasket! Seemed like it was part of the block it was so well on there.
Has anyone made a plate up with aftermarket push buttons? Was thinking a sheet of carbon sandwiched between wheel & boss and buttons.
Renaultsport 4 Button Cruise Control Panel
A 4 button carbon fiber panel to retain the OEM cruise control functions in Renaultsport Clio, Megane & Twingo for aftermarket 6x70pcd steering wheels with fully plug & play wiring made and sold by Volantechvolantech.co.uk
huh, that’s great thanks. Thought I’d be the only nutter keeping cruise on a track wheel!
Washed it and also revealed the bad scratch (only one on the body through the paint) that my neighbour kindly done with a bed frameProper fuckin gouge!
I’m really gutted about it, worse than I would be if it’d been either of my imprezas.
Is it the angle or is your front tyre flat?
Picked up a cheap new bonnet, unfortunately some peoples idea of mint isn't in line with mine
You need to take the front of the radio off and remove the buttons mate! It’s easy enough to do you just loose the logoSo I found out that you can't clean the sticky coating from the face of a Cabasse Auditorium without losing all the print from the face. It's not sticky now though!
Yeah I've done that but the text comes off with the sticky s***You need to take the front of the radio off and remove the buttons mate! It’s easy enough to do you just loose the logo
I did think that but couldn't decide if it was ottGet little stickers knocked up.
Oh damn! hope its ok?!Saved It From The Floods.
First Picture = The Street
Second Picture = My Bike
Third Picture = The Trophy
View attachment 1492867View attachment 1492869View attachment 1492871
