As my youngest son would say 'Today was a bad day!'
Got my cheapo cat delivered so set about fitting it, pre-cat lambda fitted, post-cat not so straightforward. The threaded union on the cat had been welded on misaligned to the hole in the pipe meaning it fouled the tip of the sensor. I decided to get my dremel out to grind a clearance for it, this may have been a mistake as when I wound the sensor in it tied up just before seating on the sensor crush washer. Despite trying to remove the lambda carefully it totally Fecked up the thread so now I have a ballsed up lambda and a tampered cat. Selling a genuine cat isn't such an attractive deal all of a sudden!😤
Took the car to mercedes for a recall. Pleasantly surprised that they washed and hoovered it, but annoyed they didnt wipe the door shuts down. :(
Put it on charge while I went boozing at the neighbours and then fired it up. Gave it some revs when warm.and heard the neighbours 3 doors down dog barking😂.
Mounted splitter and all the supports. This will do.
took off the arch liners and gave them a clean then coated them with ACF50 and Chemical guys on the plastic arches
View attachment 1535037IMG_20210422_153729 by matt eaton, on Flickr
View attachment 1535038IMG20210422095436 by matt eaton, on Flickr
View attachment 1535039IMG20210422095440 by matt eaton, on Flickr
View attachment 1535040IMG_20210422_153748 by matt eaton, on Flickr
View attachment 1535041IMG_20210422_153826 by matt eaton, on Flickr
With the ACF50 - do you just spray it on and that's that? Or should you wipe it on or do anything in particular? It seems to collect all the shite off the roads on my coilovers.
I brush it on. Just make sure parts are cleaan and rust free etc... It goes a long way.
Finally wired in my underseat sub that I’ve had sat in the box for a couple of months. I went with the In Phase USW300 as a cheaper alternative to the usual Alpine one people use, fits perfectly and sounds great.
I have Alpine SPG components in the front and matching rears, all hooked up to an old BT Kenwood head unit I got from @Gus a few years back.
Looks like the sub is on offer here at the moment, I paid £100 on Amazon for mine - In Phase USW300 Underseat Sub
Interesting, I've just been looking at ducting ideas again 😂
Will they clear the tyres on full lock?
Near side had no issues, offside needed some persuasion with some cable ties, ‘cheap’ plastic though so can only assume manufacturing issue or damaged slightly in transit from the US.
FYI these are £75 posted via eBay global seller program with all tax, shipping etc
It's actually mad how close of a fit they are to looking factory 😂
Did you just gamble on them fitting, or did you measure stuff before ordering?
Stole the idea off @FPummell in his project thread who I believe saw the idea elsewhere I seem to recall. Its funny that the bolts even line up perfectly as well, all I had to do to keep it solid (other than the cable tie) was to drill one hole at the front of the ducts (as pictured above).
After 3 years good years of ownership. My Cup ran out of mot and had been sitting in the front garden for some time so I decided to give to a mate for a project. Safe to say he loves it, i did, who wouldnt. Just glad to see it go to a good home. He said he wanted use it as a track car but by the time he got it home he knew it had to be his new daily.
By far the most fun, enjoyable and rewarding car ive owned (cheap too)
Belts, pulleys, and water pump done this afternoon, left the timing to my mate as he's got all the proper tools and done quite a few over the years.
All ready to get swapped over tomorrow 😎
Nice work. Doubt she'll need that doing again in her lifetime? Timing's easy i only destroyed one engine learning how to do it properly.. Its been plain sailing from then onwards :ROFLMAO:
I'll do anything else myself but leave the belts to the expert 😂
The car will be for sale soon, not sure how much value it'll add but there was no way I wasn't putting belts etc on it while it was apart. The clutch I put in last year when the gearbox was changed has still got the writing on the friction plate 😯
Been taking my time on it today but it's half finished now, new engine is all bolted upto the box ready to go in first thing tomorrow.
Fitted a new rear exhaust mount. 2nd one in 3 months. Last one was from eBay and looked a bit dodgy when it arrived. Sure enough it collapsed after a few weeks. Then last week the rubber fell out of the mount.
Replaced it with one of those ‘updated’ ones with the purple insert from BTT. Hoping this one will stay in place
Meant to ask about genuine Renault water pumps at the weekend when I did my engine change.
Do they always come with the hole for the cam belt cover untapped? Wasn't happy at having to do it myself 😂
i fitted led headlights to my mk4 rs. other weekend i fitted led tail lights too
