Noob with a Recaro question - RS265 Recaros into an RS200
  Clio
Hi, I'm new to the forum. I have had my Clio RS 200 Cup (mk3) for a little over a year now and am loving it.
I have got to the stage where I want to tweak it a little bit and have picked up a few things from KTR (although the shipping costs are pretty awful as I'm in NZ). One of the things at the top of my list was a set of Reacros. I did not think I'd find any, as Renaults aren't as prevalent in NZ as the UK.
However, I stumbled across a set from a Megane RS 265, which I'm stoked about. The only problem is that the Recaro seat base/subframe is not plug and play into the Clio's floor bolt holes. Is there a way to change the base and make the seats work? I see that this has been mentioned in the past - https://cliosport.net/threads/recaro-seat-info-updated.95314/page-5 - but I can't find answer. No doubt this has been discussed a lot, but my searching skills are obviously below par. Can any one provide an answer, link to a thread that would help, link to anyone who fabricates bases?
Cheers.
FatRS
  Megane 250
Don’t take this as the full answer, but I was under the impression they were bolt straight in?
Don
  182 & LY Clio 220 ed
@JON FOZ may be your man. He has the Megane Trophy R so will know the floorplan and holes for mounting plates. See what he comes back with as I've tagged him.
-KarL-
They should bolt straight in if you can still get hold of the correct subframes, the only thing you might struggle with is the tilt/slide function.
Years ago i got my Recaro subframes from capital seating.
  Clio
Thanks, I'll check that out.
