I use a flannelJesus that shock boot has seen more action than @Yorkshire Pudding ‘special’ wanking sock
Got a day or two until that happens, depending how quick RPD are at delivering stuff.Can't wait until the "are these top mounts supposed to look like this?" and there's a big f**k off gap between the top of the strut and the top mount 😂
I like your private plate.I feel bad just leaving it up on axle stands, everything was going so (relatively) well
Press F to pay respects 😔
Two of the previous owners actually fitted private plates, presumably as they were too embarrassed to drive around with that standard one.I like your private plate.
Tune in tomorrow for more shenanigans. I'm going to attempt to do an oil change, so I'll probably end up needing a new sump, or I'll fill it up with coolant by mistake. And if that goes well I'm going to attempt to fit some shifter bushings 🧐
Surprised this hasn’t gone Gold yet.
Take the fuel rail guard off, it's a doddle to do and it'll make life much easier for removing the filter.Update: Went outside to change the oil today. Saw how little space there is around the oil filter and decided I'd rather be doing literally anything else so I went back inside.
I'm trying to decide if I should go to Halfords and buy some deep sockets, or wait for my daughter to come home from school and see if her hands are small enough 😂Take the fuel rail guard off, it's a doddle to do and it'll make life much easier for removing the filter.
I find using a normal sized socket and one of these bendy knuckles gives you enough reach to get in to the nuts.I'm trying to decide if I should go to Halfords and buy some deep sockets, or wait for my daughter to come home from school and see if her hands are small enough 😂
I've been there..learnt from it!!Only one side jacked up
Rookie 😂
What torque setting is the sump plug supposed to be? I've done 20Nm for now, is that enough?
Yeah I have. Cost me £17 for some new deep sockets to remove the fuel rail guard, but other than the crippling financial pain it went pretty well 😂Have you changed the oil filter yet? It's a piece of piss you mongoloid.
Oil is oil 🤷♂️Dont worry, I put engine oil in the gearbox.
Do what I did. Ripped the injector cables trying to take the oil filter off. Then fuel pissed everywhere out of the fuel rail after.
Everything FT
Oil is oil 🤷♂️
