Battery Nonce
It seemed like a really good idea at the time but in hindsight it might have been a bit too bright 😂I'm glad you brought the sun with you to CSF
My eyeballs are still recovering
Thanks maateee@Iranian Pudding, @Louis - these are all the die grinder bits I've bought and like. The flappy pads are by far the best things for removing rust..... Louis 👀
10pcs 2" 50mm Roloc Quick Change Sanding Discs 60 Grits Surface Conditioning Pad | eBay
Type: Roloc quick change discs. Quantity: 10pcs. With high elasticity, good self-sharpness, grinding efficiency, good heat dissipation, low noise, long service life. Maximum speed: 20000rpm. Material: Zirconia, fibre with plastic screw.www.ebay.co.uk
3M Scotch-Brite Roloc Bristle Disc 50mm 2" x 1 | eBay
High speed discs for most right angle tools These 50mm Scotch-Brite™ Bristle Discs remove paint, stains, adhesives, weld burns, rust, heavy oxides, and surface contaminants from large areas quickly and easily with light pressure from the operator.www.ebay.co.uk
2" / 50mm polishing pad with spindle | eBay
Find many great new & used options and get the best deals for 2" / 50mm polishing pad with spindle at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Roloc 50mm Quick Change Backing Pad Holder & Arbour X1 | eBay
& Arbour X1. 45mm x 6mm Arbour will fit most Rotary Tools. Suitable for most 50mm Roloc Abrasive Discs.www.ebay.co.uk
35Pcs 2" 50mm Roloc Type R Roll Lock Quick Change Discs Die Grinder Sanding Pads | eBay
Ideal for deburring and surface prep, gasket removal, coating removal, cleaning wed splatter, removing heat discoloration, blending and finishing. Suitable for sanding stainless steel, standard or alloyed steel, non-ferrous materials and alloys, plastic and fiberglass.www.ebay.co.uk
I use these,Thought I’d ask here. Probably sound like a pussy but I’m fed up cutting my hands and scrubbing f**k out them after working on the car. What gloves do you guys use? I’ve tried nitrile - last about 2 minutes. I’ve also tried workie gloves but they’re too thick and you can feel anything.
It was so f**king bright.It seemed like a really good idea at the time but in hindsight it might have been a bit too bright 😂
Tiger grip they orange ones with the wee knobbly bits on themThought I’d ask here. Probably sound like a pussy but I’m fed up cutting my hands and scrubbing f**k out them after working on the car. What gloves do you guys use? I’ve tried nitrile - last about 2 minutes. I’ve also tried workie gloves but they’re too thick and you can feel anything.
Only taken you 2 months👀😉🤣🤣@Iranian Pudding, @Louis - these are all the die grinder bits I've bought and like. The flappy pads are by far the best things for removing rust..... Louis 👀
Are they quite thin then? They look exactly what I’m afterI use these,
They have brilliant dexterity with the only downside being that they are not 100% oil proof like nitrile would be. But they last.
I got the pack of 24 pairs 2 years ago and I've only just opened the second bag (comes in 2 packs of 24 gloves)
24 Pairs PU Coated Black Nylon... https://www.amazon.co.uk/dp/B01MU9MGYF/?tag=cliospnet01-21
Very, I was in your predicament before and kept splitting nitrile and absolutely hate the thick gloves where you can't feel anything.Are they quite thin then? They look exactly what I’m after
Now I've got the die grinder, I'm looking for bits and remembered you posted this.
I see you linked a separate roloc 2" arbour as well as the one that comes with that 35pc set.
Is the one included in the set ok or do I need to get the other one you linked?
I cant remember who it was that posted the cheap USPRO long aviation spanners in here, I ordered a set and have sat on them for about 6 months never needing to use them. Doing a timing belt this weekend, wanted to get a ratchet spanner on a nut, couldn't get enough purchase on it to crack it loose....
Saved the day!
Cant take you seriously you have carpet on a bench!!For what I need it for and how cheap I got it, it’ll do for now 👍
Your ma's got carpet on her vagCant take you seriously you have carpet on a bench!!
Same one I bought my dad after snapping his vice in half pushing a bearing into a housing🤣🤣Well if we're showing off our vices, I found this in my Grandma's garage when we cleared the house, it was in the pit and would have been my Grandad's a long time ago. It's a tad overkill for my use 😂
Yes I know the bench is too low and narrow
I bought these as well been handy for a few hard to reach tight ones.I cant remember who it was that posted the cheap USPRO long aviation spanners in here, I ordered a set and have sat on them for about 6 months never needing to use them. Doing a timing belt this weekend, wanted to get a ratchet spanner on a nut, couldn't get enough purchase on it to crack it loose....
Saved the day!
Can anybody recommend any low torque slimline spanner sets? I used a snap on one recently to undo a fuel fitting with slim hex nut, was great compared to my angle grinder thinned out spanner. Snap on set is about £400 so id like a cheapo half decent quality set.
Bang on cheers gents. They are one of those tools that you will rarely use, but come in handy for alloy fuel fittings with thin hex on the end. Saves grinding down a spanner😆
Do you not have a set of spanners that have been thinned out with the grinder?Bang on cheers gents. They are one of those tools that you will rarely use, but come in handy for alloy fuel fittings with thin hex on the end. Saves grinding down a spanner😆
I have a couple that are modified for the task intended i needed to take a fuel line fitting off at Efi last week and id forgotten my grinded special and Chris let me use a posh snap on set of low torque spanners for the job. Got me thinking an upgrade might be needed. Ive got a few sets of odd job spanners, obstruction sets etc, for that one job they make life easier for well worth having.Do you not have a set of spanners that have been thinned out with the grinder?
I have a 13, 15, 18 and a 19mm that have been thinned out 😂 I think my dad bought a separate set and then just spent 20 mins on the bench grinder 😂
Oh aye you're not wrong mateI have a couple that are modified for the task intended i needed to take a fuel line fitting off at Efi last week and id forgotten my grinded special and Chris let me use a posh snap on set of low torque spanners for the job. Got me thinking an upgrade might be needed. Ive got a few sets of odd job spanners, obstruction sets etc, for that one job they make life easier for well worth having.
Thats hoora cheapSnap on are £200 for cash on our van, up to 36mm
