Call of Duty Modern Warfare
Ant1
Brembo! Brembo! Brembo!
First damge range on Type 100 is 17.5m and PPSH is 8.3m. Your right about hipfire but 50m? You installed hacks again? 😂
😂😂😂 I’ll stick up the build tomorrow so you can give it a try for yourself. You’ll see.
Adamm.
Cheers mate it's probably the same build I'm using and the same meta build most people are running right now but stick it up and I'll have a look..
You know you get armour brake even when you strip half a plate off someone right? 😂😉
Cub.
Season update yesterday?
Yeah, there is a new AR aswell, BP50 or something. Bounces around a bit, but is pretty punchy... as noted on Plunder yesterday...
Ay Ay Ron
New LMG too.
15 long shot kills using any weapons to unlock it.
I've just unlocked the BP50 in one game of shipment but haven't used it. You need to use the 3.5 rifle scope if using a vanguard weapon as they don't have ACOG optics. ACOG on MW/CW weapons will work though.
Cub.
New LMG too.
Yeah, and there is a fault with the tracker, which doesn't show your progressing the challenge on the BP50, but you are. Can use the G16 2.5X to unlock on Vanguard aswell.
Ray Gin
  Cupra Leon & Impreza
Loving the free hacks!
Miss the shot, yet still get a down.. 🤔
I can only guess there was someone stood behind the hut and I’ve downed him through the wall?
Cub.
Just before matey in the white tracksuit pops back out, you see movement in the back room. I reckon that’s who got downed.
Ray Gin
I’ve upped the brightness and paused it frame by frame and can’t see anything 🤔
Cub.
@Jonnio - stick this in your Caldera Fever
- This is just before the down, look at the light in the doorway, half “floor to ceiling” in the back room
This is the down, where half that light has disappeared, and it’s not matey boy in his white tracksuit, as you can see him… it’s someone moving in the back room. Which is who gets downed….
Get some better eyes boys 👀 x
Ray Gin
I don’t see it
