Captain Hat
CS Academician
2002 Clio RS 172 Cup
Right, so, did a quick keyword search and didn't find what I was after. It could be that my search-fu is weak, but that being what it is I figured I'd go ahead and ask:
I have a Clio 172 Cup. Had a crash a year and a half ago. The pretensioners on the driver's side fired, and when I plug my OBD2 reader in it says there's a permanent fault code and the ECU has locked itself because of the crash. There are a few people online saying they can reset the "airbag ECU" for between £30 and £70ish but I'm not sure i trust them. I am also not 100% sure what I'm dealing with here;
-Is this an issue with the UCH, or is it a separate module?
-If it's a separate thing, where is it, and is it hard coded to the UCH/ECU like they are to each other, or can I just replace it with a second hand one?
-Has anyone used one of these crash data reset services before? Were they reliable?
-Is there anything else I need to know?
This is, as far as I can tell, the last thing I need to fix before I can get it MOTd and back on the road. It's proving to be a little confusing for me so far, and as such is quite frustrating. Thanks in advance for the help!
