Grams rear disc spacer orientation
Car  Clio 182
Evening all,
Quick question, the OEM rear disc spacers we’re missing on my 182 so have purchased a set of grams reproduction disc spacers
Question is, which orientation are they fitted given both sides have a taper and a flat side it’s not immediately clear
Any direction/ help appreciated so I can get the car on its wheels again!
Thanks
Just for the avoidance of doubt, the bottom image should sit towards the car?
Just as the other side still has a inner taper albeit smaller
Much appreciated though! 👍
I can't tell by your images tbh. The larger taper towards the car/hub.
The Flattest side sits against the bearing in the disc if that makes sense.
Fag packet illustration 😂
My writing’s atrocious 😱
😂 that’s great thanks 👍
I hoped that would be the case as it’s the way that makes sense to me! Just want to avoid fitting one way and being forced to strip it down and reverse!
Thanks again
