‘Bonnie Blue’ The RB 182
Advikaz
Can I ask what lids you recommend?
I had a Schuberth which I loved, but bought an shoei lid, it’s noisey as f**k. I hate it! 😂
Hi mate,
I’ve always been an arai man. But I would suggest going to a shop and trying a load on and seeing which fits the best :) the top end of most top brands are usually good.
Oh and worth looking into a decent set of custom ear plugs.
For what my opinion is worth, spend as much as you can afford. For bike circuit stuff I use Rx7v. Race type lid might not be the best option for road stuff though, ofc.
Car stuff, again always used arai. Gp6 or now gp7
Advikaz
Didn’t get much done today.
Spent an age pissing around with the PMS shifter trying to get the bearings out. Given up, and will probs just order new assembly.
The bearings in mine are all completely shagged. Not sure how long they’ve been in but they’re all seized solid.
Got the oil and filter done though at least. So one thing ticked off the list.
Second time changing the oil and filter on this car, I suspect the person who designed the filter location wasn’t someone who’ expected to ever have to change one…..
Advikaz
🚨 Update time 🚨
Here's what I can remember that's been replaced on the car so far. lol................
  • BC Coilovers
  • SuperPro Camber bolts
  • WhiteLine ARB
  • Hel Brake lines
  • Corbeau Seats
  • Seat mounts & Rails
  • OEM Oil filter and sump plug / washer - 2024
  • Trw rear pads
  • PBS Pro race front pads
  • Godspeed J hook discs
  • Seat receivers
  • Wheel cover
  • Nuts and bolts for seats
  • Millers NT+ Oil
  • Voluntech steering wheel Switch Gear
  • Sabelt RenaultSport Wheel
  • Momo/Ktec Hub
  • Full Geo
  • New OEM Bonnet
    Paint front end
  • Dent removal
  • KTR Induction kit
  • Battery cover
  • Modified manifold VBand to mid pipe
  • Miltek non Res Exhaust
  • New calipers (rear)
  • Motul RBF700 Brake fluid
  • Rear oem and rear discs and bearings
  • Rear rear disc spacers (Grams)
  • 10mm PMS front spacers
  • Poweflex dog bone mount
  • Powerflex engine mount
  • Proline replacement rear brake pipes
  • BTT poly exhaust hangers
  • BTT exhaust bushes
  • New OEM Renault upper and lower inlet gaskets
  • New NGK plugs
  • All injectors replaced - magneti marelli
  • New NGK HT leads
  • New Valeo OEM coil pack
  • Redline MTL gearbox oil
  • Carbon fog surrounds
  • Replacement doner gearbox (60K) – Fully rebuilt by Northloop
  • Soda blasted gearbox.
  • OEM gearbox end cover and seal.
  • Sachs performance clutch kit.
  • Replacement OEM clutch tube.
  • OEM clutch bolts.
  • Blackline LSD.
  • Redline MTL gearbox oil.
  • Redline Power Steering Fluid
  • New Drive shaft boots
  • Lemforder Ball joints.
  • Lemforder Track Rod Ends.
  • Refurbed wishbones with Pure Motorsport Plates.
  • Refurbed Front knuckles
  • New hubs
  • Refurbed subframe, supports and ARB
  • OEM SNR front wheel bearings
  • Ktec Carbon splitter
  • OEM inner track rod kit
  • Powerflex arb inner and outer bushes
  • Powerflex wishbone bushes
  • Powerflex steering rack bushes
  • All new zinc coated high tensile bolts and nuts throughout the front end.
  • Evol engineering upper gearbox mount
  • OEM front abs sensors
  • Paint touch ups at bodyshop
  • Full paint correction & Seal
  • ACF'd underside
  • JP Cages Half Cage
  • Carbon cage protector
  • Racecool wishbone brake ducts
  • Oil and filter change (millers nt+ and OEM filter) - March 2025
  • Merlin Harness eyelets
  • Sabelt harnesses
  • PMs shifter rebuild kit. All new parts. Upgraded bearings. NMB ABT12
  • Fresh geo.
  • Speedline 2118 (Ktec motorclub lightweight wheels)
  • Nangkang AR1’s x4
  • RST Remap
  • Ghey number plate
And a Partridge in a Pear treeeeeeeeeeeeee
Mr Underhill
To be fairrr
That looks nice, but will probably melt or worse, set on fire. Designed for door trims.
I must have had 3 sets of original exhaust trims over 7 years of ownership. My biggest issue is the PMS exhaust tips expand, a lot, and melt them. It’s partly why I opted for 3” rolled tips over the 3.5” slash cut ones. The stuff I use is for commercial purposes and is designed to withstand heat. Popular on track/race cars.
