172 Cup OEM+
bowen86
Another small update.
In the effort to keep things OEM+ I've decided to swap in a PH1 Stalk with a horn and a genuine Sabelt Steering Wheel.
That's this weekends jobs sorted...
Mr Underhill
They do look a bit odd and out of place. God knows why they're brown?
Rust - they've been cleaned up but start to corrode immediately unless treated. To retain the "metal look" ACF-50, machine oil, WD-40 can hold the rust back, but a bit of a chew as it soon dries out. I use a clear coat, which does that job or a Cold Blueing oil - for guns - which leaves them Black.
MRBILLYUK
  FF Jeden Osiem Dwa
I stand corrected. I've just been to fill the screen wash up and checked mine. They are lightly coated in rust. I've had the car since new and they've always been rusty as far as I can remember lol.
bowen86
Not much happening in the Clio space at the moment.
Plans are to still drop the rear beam and do a bit of undersealing and maintenance etc.
I picked up a spare Turini from a nice guy from Carmarthen called Andrew. Said he was a member on here.
Genuine, straight, cup offset Turini.
Refurbed and a tyre stuck on it.
Just adds a little something to it IMHO.
I was also contacted by a youtuber to take part in a video.
Hahaha, ignore that jaunty pose in the thumbnail!
I make a few mistakes and I'm sure I am plain wrong in other areas but have a watch if you've got some spare time. I do give a special nod to CSOC. 👍
Greeny.
  440i + 182
CSOC? You taking the piss mate 😂
Louis
I Love Ed Sheeran
Wish Tyson Fury
npt
  BMW 320d- 172 cup
Two coats of bilt hamber uc has fairly held up on mine over the years, needs topped up afyer 2yrs I'd say and discolours slightly,I I've mine out in all weather, still looks good underneath 9yrs on 👍
172CupHGA
  Clio 172 Cup
Fel
So I thought I'd solved the brake bias valve leaking, but in the slippery panic of brake fluid up to my elbows I managed to do something silly and cross threaded the brake line going in to the N/S rear caliper. Doh! Ordered a new one and all new braided lines for the bias valve and the calipers and of course a new caliper.
I must have bled the brakes a hundred times and eventually it was all sorted.
Now, I've owned a few Clios and I know with a few subtle mods they are a much more pleasant place to be/car to drive. That said, I won't be going the track car route, I still want rear seats etc.
First up I spotted a BMS shifter for sale. I've never had a BMS only PMS and as I wanted to keep this Clio 'user friendly' I knew that a PMS may not suit my needs. Yes it's a great shifter but it rattles, yes you can solve the rattle but I couldn't be arsed chasing those rattles. So I opted for the BMS.
Fitting was easy. I also sprayed the shaft black as the standard metal looked out of place.
It looks and feels like a PMS, ok it hasn't got that 'Lee Enfield bolt action rifle' feel of a PMS but it's silent and brings the knob much closer to the wheel, which was ideal.
Then a smaller steering wheel was purchased. I'm in the process of giving this a really good clean any tips on what to use or how to clean it let me know.
The six button panel came with the wheel and boss. On the look out for a two button panel.
Lastly, for now anyway, Seats.
The Cup seats are actually quite comfortable and more hugging that the normal part leather RS seats. However, they're just too high for me at 6ft 1. So I picked up a pair of seats, runners, sidemounts and bases up.
Now, I am tempted to leave the Cup passenger seat in place as the whole idea of this car was to make it 'family friendly' and this means access to the rear seats. However having one bucket in there is messing with my OCD slightly.
I know the answer is reclining buckets but I could find any I liked. There doesn't seem to be a method of having a tilting bucket seat, so this is it for now.
Next...
A clutch. The clutch isn't slipping, but moving off in first gear without stalling is impossible! I know Clios have a heavy clutch but the bite on this is right at the top. The cable looks original and a bit knackered so that's being replaced too.
Looking for someone or somewhere to do a rear end refresh i.e. drop the rear beam and fuel tank underseal etc.
Suspension. The struts and springs are looking a bit crusty so I'll replace them at some point this year. Coilovers, maybe Bilstein or BC's.
Where did you get the BMS shifter from please? How has it held up over time?
Lovely car - will keep an eye out as also based in South Wales.
bowen86
Fel
BMS was for sale on FB. Quite hard to come by now.
Feels OEM but a better position and not as bad at rattling as a PMS. It doesn't however have that PMS feel.
bowen86
Doing some bits over the Christmas break.
Rusty bumper brackets, worst grinder back, deox c gel and Hydrate 80 before throwing some paint on it.
Current situation.
Looking to build up a second rear beam to fit.
I'm assuming a 182 beam does fit but has slightly more strengthening to it?
Stub axles, I need help sourcing some for a 172 Cup, HELP?!
bowen86
Not alot happening as it's booked in for having the beam and fuel tank dropped and undersealing etc.
I previously mentioned I'd bought a spare Turini but the original tool kit wouldn't fit or rather thread on the bar in the wheelwell. Thanks to @Mattcup for the recommendation of using a yellow spare wheel tool kit thread. The wheel now fits.
Yes the wheel is face down, but I've used a few microfibres to protect it. The wheel won't fit face up with the tool kit below it, I've tried.
Also, I had the strangest knock and I was convinced it was coming from the rear suspension, until I noticed I could get it to happen whilst tapping the accelerator.
I was even more convinced it was the rear exhaust mount. But that was solid.
Then I pushed the centre of the exhaust and "knock knock, who's there. Centre exhaust mount"
You can just about make out where the rubber has worn away and the metal ring was tapping away at the exhaust hanger.
Fitted and OEM one and away we went with no knock. Hurraahhh...
Next plans as I mentioned, bit of maintenance and undersealing under the fuel tank etc.
Suspension, the current shocks and Cooksport springs are looking abit tired.
leeds2592
  Bean 182 + E70 X5
Are the wipers in the ‘parked’ position? Nearside one looks to be sitting quite high
bowen86
Great question. I've tried getting them in position for a while, but the passenger side keeps touching the drivers wiper when it comes to rest. The only way to get them not to touch is to raise the passenger wiper.
In trying to sort this out (again) today, I noticed the spline on the passenger side was almost smooth.
So I scraped the dirt out the spline, assuming it would work. But no.
I cannot get the passenger wiper to sit nicer without it touching the drivers wiper when at the lowest/reset point.
I did notice than the teeth on the passenger wiper aren't great, so perhaps it's slipping off the spline?
Had Saturday morning to myself so took the Clio for a blast up the Breacon Beacons.
bowen86
Dropped the car off to a local place for removing the rear beam, tank and exhaust etc and having any surface rust treated with dinitrol RC900 and undersealed with dinitrol 4941 and lastly front wheelwells treated with dinitrol 4010 and a linolin based coating. Also the rear beam was given a lick of paint too.
Before
Bits off
After
Really happy with the outcome.
bowen86
Lovely mate,how long did they take to do this?.was the rear beam powder coated?.
Took just over a week. They had to get it done quick as they had bigger projects to smash out.
I had originally planned to refresh a second beam and supply that built up with rear brakes and bushes etc. But the second had beam I'd bought had a rust hole in it which I wasn't aware of until the powdercoaters noticed it. I also couldn't reliably source 172 cup stub axles.
The garage I used couldn't settle for refitting the scabby beam so they treated that too, which wasn't in the plan but they chose to do it.
As above but with approximate cost of the work done too?
I don't mean to gate keep I'm just reluctant to publish the price as your car might need more work, also I find location matters, I'm in South Wales and I can guarantee this work would cost more closer to London for example. If you are seriously considering this type of work, you can message the garage direct and they can tell you:
https://www.facebook.com/share/19Zp3kw6wc/
As an approximate it was four figures, just. Very reasonable price for the ammount of work and the quality.
bowen86
To finish of the rear refresh I thought it rude not to add some new rear discs and pads.
Sure we've all seen what old discs and pads look like but for the sake of documenting it:
Before
After
Looked like one bearing was on it's last legs as this rubber (at one time was rubber maybe?) seal decided to just fall out.
Also gave the hub spacers a spruce up and made sure to install them the right way around, thanks to info found on here.
And why not...
bowen86
Flat side to bearing/disc and tapered side to car.
It's not immediately obvious which side is tapered until you hold it in your hand. Even that above image, not really sure what side that even is! 😂
bowen86
Now every Clio I've owned has had floppy inner TRE's and the the outer TRE's aren't usually far behind. Neither aren expensive so I did my research and bought some fresh ones.
The ones on there weren't that bad to be honest and at one point I did consider sending the back, getting a refund and sticking with what was in there. But, I had a free morning, the tools were out and the podcast was blasting so I thought why not.
Ignore where the nut is on the thread I did count how many threads it took took get the outer TRE off. Tracking will need redoing but it's not all that far off.
Not an exciting or photogenic job but here you go. 😅
bowen86
Hunting rattles and I'm snooping around the boot area.
The boot latch. Is it adjustable, I seem to recall reading that they could be adjusted but I can't see how?
@Brigsy I think it's your thread I read where you adjusted the boot latch?
  • 20250321_112811.mp4
    13 MB
bowen86
Made an amazing mistake yesterday.
In an effort to bring this up to scratch I thought I'd replace some of the cooling system, namely the radiator, thermostat and thermostat gasket.
All was going really well.
The coolant that came out was OK. But the radiator was a bit crusty around the edges.
Feeling quite proud of myself here. I was making good progress and in a good time too (I'm an office worker 😅).
I'd fitted the thermostat and gasket. Not many photos as I needed two hands.
Old radiator
New radiator
At this point I was flying.
Until (and if you can tell what the issue is already, 10 CS.net points to you)...
Yeah, wrong radiator. Balls.
I bought this new one a few months ago, doubt the seller will take it back. Anyway, ordered the correct radiator this time.
I did notice some crusty bits under the front T slam panel thing.
As well as the radiator mounts.
These are all now wrapped up in Deox Gel.
Will sort those scabby bits out and sat here waiting for the correct radiator to turn up.
Colin-S
  172 Cup
Did you order this radiator?
Old thread with correct radiator
bowen86
The new (and hopefully correct) one I've bought is from Ebay. Seller has it listed as a 172 Cup and specifically says it's for non ac models and a 172 Cup only. So they seem to know what they have listed.
I asked them to send pictures of the mounting for the fan and the top mounting brackets too as that alters from AC to NON AC models.
Fingers crossed.
Matt Cup
  Leon Cupra, 172 Cup
Hey, do you know if the rad pipes are cup specific or they are standard across the range?
bowen86
I'm going to say standard. Only reason there's a specific rad is because of the mounting brackets for the AC condenser. The inlet and outlet of the radiators are in the same location. So the same.
I think.
bowen86
An update.
The correct radiator arrived, with a day to spare as I have the Cup booked in for an MOT.
Correct rad with mounting points for the fan.
Went in like a glove
Bleed the coolant until the fan kicked in.
Took it for a little spin (Private road as I have no MOT, officer) and it's running well. The temp gauge is sitting ever so slightly above 90, but it did with the old thermostat too. From what I've read on here it's quite normal?
Anyway...
Will update post MOT.
