Monaco 172 Track Car
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
You don't have much luck do ya! 🤣🤣🤣
It makes for good reading though and I love reading how you overcome these problems
Fair play mate
Sone serious perseverance
I Changed My Name
I thought I'd have a really relaxed day today, since it was raining again and I didn't wanna be out getting piss wet through
I started out running the car in gear, making sure it goes through them all. Everything went fine and dandy. I remembered to drop the passenger window this time too🤪
But my brain got the better of me after running the car up. Since it was already warm I decided to change the oil and filter
New oil and Purflux filter
Been 1 year since the last service
Marked the filter up
At this point the oil was flowing out and I had no issues. I couldn't find any dowty washers in my filter box... s**t
I was in luck that I hoard everything. I had 2 copper washers in my engine build box... You know, that engine I've been saying I'll build for the last 3 years🙃
Copper washer found I was back on track. It's a good job I had them too because the copper washer assortment pack only went up to M14, looks like I'll be buying in some M16 ones
Oil filter off, this was a doddle. But then as soon as I went to remove my oil filter pliers I knocked them into the the oil pressure sensor and it gave up. You can see just how crusty the 23 year old sensor is
Not to bother. I had a Clio 200 engine in the back of the garage so I pilfered the sensor out of the bag of parts
Except that didn't go too well since Renault decided to change the connector from the F4R736 to the F4R830. t***s
Gonna get a sensor from one of the engines at work tomorrow. If not they're only £7 so it's not the end of the world. The eagle eyed viewer at home will notice the date mark isn't on the filter, it smudged so I wiped it off and rewrote it whilst the filter was on the car.
I've re-written my list now so I've got some stuff to work on. Now we're getting to the finer details
I Changed My Name
Last night @Louis came over to give me a hand and to bring me some parts
Before he turned up I got the oil pressure switch swapped out. Managed to steal one from one of the engines I have at work
After that we were off to a flyer as you can see... Got the upper rad support bolted in, it fitted perfectly
One of the bonnet latch bolts went from slightly tight, to slightly loose, to 'get the tap and die set out chief'
The metal is piss thin so I opted just to drill through and send a pair of M6 rivnuts into it instead
Whilst I was f**king about sorting that balls up Louis had got the new to me EVOL dogbone mount in, the gearbox drip tray, cleaned up the spare discs he brought over, fitted those and started fitting the BYC Brembo ducts
It was at this point I asked him to try the shifter and see if it felt right. It was a bit s**t to go into reverse, which meant the PMS shifter magician had to get his cloak on and we he set about adjusting it. Took us about 15 mins to get it spot on
It actually looks like a car again now, the bonnet shuts too (doesn't line up though🥴)
Tonight I'll be tackling the jobs in red. I ordered some 50mm bass ports for the BYC ducting. The Ali ones that came with them look a bit naff
I Changed My Name
Started the evening by removing the bottom grille
My hole saw arbour was MIA. So had to improvise and make my own arbour for the drill. The 13mm nut centres on the bolt. Precision engineering
I bought some different bass ports on Amazon last night too. These ones that came with the BYC ducts were shite
Marked out the grille, drilled 2 holes and popped the bass ports in, slapped some mastic on the back of them to keep them in position.
Got the grille fitted back up and it looks decent
Moved onto cleaning up the rear brakes. I got a set of discs from @SharpyClio just incase mine were too far gone from being sat. Thankfully, all the corrosion cleaned off and they came up decent, even just using a wire cup on the grinder. I'll keep the others as spares
Finally. The car is back down on all 4 wheels
Moved it from that position and I can already tell the gripper is mega even from just moving it with the wheels turned🤣
Onto the last push. If all goes well, I'll pick the 5 series up tomorrow, grab my trailer, load the Clio up and take it to work for storage
Then I can work on the last few bits, clean it and give it a road test on our private road/car park
I just hope it stays working. I'm absolutely f**king shattered and mentally gone
I Changed My Name
Loaded on the trailer yesterday
Set out today to swap over my pads to the DS1.11, put my track wheels on and load the car up for tomorrow
New track wheels. Genuine X65 Cup racer speedlines, quite a bit different to the 2118 you can buy anywhere
Swapped the pads over, fitted my Titanium shims. Pulled it forward, noticed a tapping/knocking
The wheel weights were catching the nuts for the Brembo brackets. I thought they'd self clearance but after driving it I had to knock them all off
I gave it a run up and down the private road near work to bed the pads in. Pulling out of the car park I could already feel the difference in the diff🤣
Gave it a good wash
Gave the trailer a scrub down, had a few cars on it since and there was oil and fuel on the buffalo boards
Locked, loaded and lusting to have it's head kicked in
Really looking forwards to Saturday now. I was honestly thinking I might not make it in time and I'd be still crawling around it fixing it... There is still time for that like
I Changed My Name
Gonna be more of a writeup. Once all the pics have come out from this weekend I'll follow up with them
Drove down Friday, 7 hours driving time coupled with retards that can't drive. This Aygo being one of them, if you know this person, tell them to promptly die
The 5 series pulled the trailer without fault, I had @leeds2592 as a copilot. It made me realise how boring the drive usually is, it was nice to have some company
I was mega nervous about the Clio, I'd done less than half a mile in it since it's yearly gearbox removal🙃
7am arrival after a lovely stay inside of a chicken nugget caravan
Went out for the sighting laps, car felt good, I needed to bed my brakes in but couldn't really hammer them with it being sighting laps. So with that I let the mad rush happen and opted to go out 15 mins later. I got 1 lap in and started to bed everything in, as soon as I came out of turn 1 the car started spluttering with a flashing eml. I limped back to the pits and read for codes, the only ones I had were for both lambdas
I haven't slept particularly well for the past 3 weeks, 4 maybe 5 hours of broken sleep each night had really drained my brain. Any other time I'd have just assumed injector from the flashing EML. Thank f**k my mate was on hand and he stopped me farting about with the lambdas, he got me to start the car and unplugged injector #4. That made no difference so immediately we knew that was the culprit
Or so we thought
I got my spare injectors and rail and set about swapping the 'duff' injector. That then lead me to snapping the bolt that holds the fuel rail down. Thanks to @Scrooge for the positive words of encouragement at the time "I'm not leaving until it comes out or snaps, if it was me it'd be snapped already", no less than 4 seconds later I snapped the bolt so he could depart🤣🤣
With that snapped I swapped the injector, just as I was putting the connector back on I noticed copper from the plug end. Then I barely touched the wiring and I snapped🙃 So now I was left head scratching again on how to fix a wiring issue when the plug had 3mm of wire hanging out
Again, big thanks to Ryan and Ryan (or DannyDC2), his car was fully stripped so he cut out his speaker wiring which had 2 spade connectors on. So now I had a pigtail I could use and bodge fix my car with
Which resulted in this🤣
I fired it up and everything was spot on. I took it around the paddock and it seemed fine, so the helmet went on and I went out to really f**king give it some. And it was, everything was working well
I then took @OEM Battery Nonce @SunglassesStan and Ryan out and kept f**king up 2nd gear. I blame @Louis for f**king up the shifter position 👀
I mentioned I was struggling with 2nd to @Myfanwyi and his reaction was "why the f**k are you using 2nd anyway"
So with that I took Andy out for a few laps. Straight away he changed some things with my driving and said to leave it in 3rd. Lap after lap I was getting quicker, and quicker, and quicker. Apex and exit speed I was miles ahead and so much more confident
The brakes still had more in them, I was being told I was working the car too hard on the tyres and I need to let it go straight out of a corner. But my brain is actively programmed to avoid the green stuff
After a proper good session I had finally worked the front AR1s too hard and they started to go off. I can't thank Andy enough for the pointers, because after that I had the pleasure of @Sunglasses_Ron in the passenger seat. His son witnessed some horrific driving but at least his dad could call him a bullshitter because I never missed 2nd once with him in the car👀🤣
Big thanks to everyone coming and saying hello, it was amazing to put some new faces to names. I look forward to the next 12 months of online bullying, sexual harassment, name changes and outright spastication
Thanks for reading. Pics to follow
Here's one of the chicken nugget beige autism caravan
OEM Cooler Box Nonce
Or so we thought
View attachment 1753682View attachment 1753683
Jesus, that ronnie croleman is massive!
Djw John
Scotland - South
It soon starts getting out of hand with the amount of spares you end up taking 😅
I had everything with me apart from a spare coilpack, which turned out to be the exact thing my mates Cup needed 😖
You actually can't win unless you take another fully working car with you.
Between @Djw Dave and I we had all the spares you could possibly need for a FCS trip, we thought.
Then my fuel pump died and his gearbox sanded itself internally.
Myfanwyi Saunfire
Wales - South
Most people make small improvements mate. Where as, you took chunks out of your lap times with each lap. Prime example - turn 3 entry, apex and exit speed. The last flyer we did you were up by 10mph on entry, 14mph at the apex and 17-19mph on exit.
The only criticism - let it run out on exit by opening up the steering earlier 👍 For me to have one thing to point out at the end of a run is rare.
VERY rare. Kudos my man.
Brigsy
  T.Turbo
@Brigsy had a plug with him too🤣
I think I'm gonna keep crimps and connectors with me from now on ffs
Ive had a pre wired ev1 injector plug in the trackday box for years, you would have been welcome to it mate.
Need a CSF whatsapp group for stuff like this next time to shout out for parts if needed 👌
I Changed My Name
CSF pics, TurboRenault taking some really good pics
These are the ones I bought
I'm glad I got one with my mates car, he repainted it in Porsche Malachite green a couple of months ago. It's f**king rapid compared to mine, made 230bhp on 197 pistons, 421 cams and some Jenvey bodies, it's been that power for about 2 years now 😂 It's pushed me and I really want to put an engine together for mine now
I have the vast majority of the parts;
  • Tessa inlet
  • 200 pistons
  • 200 rods
  • 200 cams
  • 200 crank
  • 200 valves
  • 200 valvesprings
  • Main bearings & thrust washers - Need to buy
  • Rod bearings - Need to buy
  • ARP rod bolts
  • Main cap bolts - Need to buy
  • Headgasket set - Need to buy
  • Bottom end gasket set - Need to buy
  • Top end gasket set - Need to buy
  • Piston rings
  • Head bolts - Need to buy
  • Megane keyed pulley 8200251569 - Need to buy
  • PMS lower cambelt protection cover
  • Genuine cambelt and dephaser kit
  • New crank pulley/dampener
  • New Genuine oil pump
  • Genuine camshaft stud
There will likely be loads I've forgotten that I have. I've spoken about it loads of times before but every time I get the time and money together to do it, something happens. First the Megane needed a new gearbox, then it needed a turbo and an engine refresh, then the Clio was my daily, then the gearbox shat itself (repeat 3 times), then the 5 series needed an engine rebuild, and new turbos, and mapping.
This winter I wanna crack on with it, she wants the house finishing too, I reckon a lick of paint in the bedroom and she'll be off my back about that, I'm halfway through doing the patio too
Castle Combe in ~2 weeks time, I reckon I'm due some new tyres soon, can't complain since I've done 4 trackdays on these AR1s, but the outer edges are looking a bit iffy, I have 2 spare so I'll get them swapped on
I Changed My Name
The PMS Whisperer came over yesterday evening after work and fettled my car
A massive thanks to @Louis, my shifter feels perfect now. I'll have to see how it fairs at Combe next week
I just need to sort my injector wiring bodge still, then give it a clean and fill it with fuel
It feels weird not having to rebuild the car prior to every trackday
I Changed My Name
Combe prep. The wiring I bodged at Anglesey had to be rectified
I had an old engine loom from a dCi Clio. I found a plug that would fit, I just needed to de-pin it and fit some heavier gauge tails as the original was piss thin
De-pinned
Re-pinned. The old tails are on the right
I then found a matching black connector in my toolbox. So rather than having 3 black and 1 brown connector I opted to de-pin it again and do it better. It would have annoyed me with the brown connector knowing I could have got a matching one
I didn't have time to properly splice it, so opted for this...
With that done. The car was ready for Combe.
Travelled down to stay with @Slowpoke Rodriguez on the Thursday ready for an early start on Friday morning
Combe, arrived at 07:45 to be greeted by the rest of the Clique. Got unloaded and noise tested, apparently it was 101db 🤣
It was a proper packed day, a few red flags in the morning, thankfully none of those were cause by any of our group. The car was near on faultless, the only issue I have now is the heat, I had @Rob and @Yosemite Sam in as passengers and both of them said the same. "Your car is ridiculously hot"
I think a roof scoop is on the cards as well the nimbus heatshield sheet I've had for the last 2 years 🤣 Oh and remember to take out the rubber seal at the back of the engine bay🤦🏻‍♂️
I was doing lap after lap after lap, sometimes over driving the car instead of being fast. At least I used the whole track though, there were a couple of people that could have gotten a 50% discount but I won't name and shame them 👁️👄👁️
208.1 miles done from unloading the car off the trailer to loading it back on🤣 That means I've done well over 110 laps of pure track driving if you take into account coming into the pits and driving back out of the pits too. I was expecting to kill off them AR1s but I reckon they've got at least another day in them if I switch them left to right
I'll add in some nice pics once I've bought them. The photographers website is f**king awful and his prices are extortionate, I need to muster up the courage to spend money on them
Polynesian
  Alpina B3, 172, 325i
I was going to start with some abuse and offensive chatter, but you don’t even know me online, so thought that might not go down very well. (Very happy to be offensive if you like though).
Please say more about that model Clio situation. Thank you please.
