ex-Chinese Dave
Handbrake on my 182 was also useless until I had the calipers rebuilt, then 2 or 3 clicks and it was rock solid. Worth looking into.
It's at Birchdown in about 10 days for new pads, cables and refurbed calipers. On the drive it's left in gear and has a brick behind a front wheel. It's a pain in the arse!
Rubicon_
  L110, RS6, Westfield
All washed this afternoon after a little haul from Auto Finesse. Even managed to get a helper 😆
helpimonfire
  '06 197
Haven't touched the 197 since I parked it up a few months ago after an evening session at Snetterton so of course I've left it to the last minute as usual, trackday booked for Tuesday and the car needs discs and pads all round, tyres swapped front to rear, a service and a general check over.
Changed the front discs because the drilled ones have all started cracking. They seem to have this little crack and then the next major heatcycle will open them right up. I don't normally buy drilled/grooved discs but these were nearly half the price of the normal HC discs.
Front pads have a decent amount of meat left although one has a slight bit of crumbling, they're CL RC6's and bloody expensive so I don't really want to change them until they're done, so I have some Mintex F2R in the spares box to change at lunchtime.
Direzzas are about done too, you can barely feel the tread on the inside 1/3 of the tyre so these have gone on the back, the ones that are now on the front have about 2mm tread left so they'll need swapping for something else in time for Knockhill in a month!
Didn't change the rears, the studs have welded themselves in and I couldn't budge them, the discs are 6+ years old and the pads are about 4 years old now, they have some life left so they'll go again for Tuesday, I'll actually change them for Knockhill though. Didn't get around to servicing the car either as it started chucking it down, the oil isn't that old anyway so it'll be fiiiiiine.
Aiden123
  Clio Mk 2 Ph 2 1.2l
Performed my first ever oil change on a car today.
Always been interested in doing my own car maintenance but shyed away from it. Got a 182 a few weeks back as a run around and decided to do the service myself.
Air filter and cabin filter easy.
Jacked up the car (another first for me). Was slightly nervous about doing it but it wasn't so bad. Used jack stands and had ramps under the front wheels for extra protection.
Oil change was fairly easy. Got none of the old oil on the floor. Thought I'd done a nice and clean job of it, to then put the funnel I'd used to refill on the floor in a moment of madness and got oil on the drive :LOL:
Went to do the spark plugs, fairly easy to get to but then found out that my spark plug socket was too big to fit. So need to get another one to finish off the job.
Overall though, first time ever servicing a car went okay.
Matt Cup
  Leon Cupra
Good on ya, it’s always satisfying getting something done yourself and saving a fortune doing so.
avstar1
  172 cup
First picture I've taken of the car, cleaned the wheels and thinking of going down to 18's, although on second thoughts the wheels look so good. EDIT: Just realised how moody the picture looks, was about to rain.
geoffn
  172 Cup
Washed the old girl, Koch Chemie working well in spite of the hosepipe ban.
Aiden123
  Clio Mk 2 Ph 2 1.2l
Another first for me today, successfully changed the spark plugs after managing to borrow the correct size socket. Wasn't too difficult.
My next task is to change the post cat lambda sensor. The emissions light is on and my code reader is saying the post cat sensor is the issue.
I've also got to sort out some wiring under the passenger seat which is causing the airbag and service light to come on.
I've then got some rust in the fuel filter cap to sort.
The 182 does need some TLC but I did buy us as a sort of project for myself to learn basic car maintenance and repairs.
helpimonfire
  '06 197
Few days ago now but me and a mate beat the ever-loving piss out of the Clio. Burned a litre of oil, 90 litres of fuel, a set of tyres and a set of pads in 200 track miles.
What a beast.
Polynesian
  Alpina B3, 172, 325i
Have you got a project thread going? Good on you for getting stuck in, it’s rewarding!
Aiden123
  Clio Mk 2 Ph 2 1.2l
It has been really rewarding so far. Not doubt I'll be screaming at it at some point when I break a bolt or something 😆
Might be a good idea for me to set up a project thread. Be a centralised place for me to record what I've done to the car and ask any questions.
ex-Chinese Dave
I’ve been pulling the gear change mechanism back-and-forth, up and down on the drive just for the shift fun of it. No doubt the neighbours are looking and saying “He’s back under that car again. Why does he bother?”
Anyway, I’m washing it after three weeks i’ve lots of driving, it’s full of sap and bird s**t. It’s an absolute disgrace. I need to move house to keep this car in good condition. I am seriously not joking.
Aiden123
  Clio Mk 2 Ph 2 1.2l
Well went to change the post cat lambda sensor on the 182 today and it turns out it wasn't plugged it to begin with. No wonder it kept throwing the emissions code!
Why would someone leave it unplugged and purposely tucked out of the way if it was just going to throw up codes anyway?
Since I had the new sensor I changed it out anyway. The sensors look very different.
Cleared the code after installing the new one and took it on a couple of drives. No more warning light... For now anyway.
Polynesian
People do some strange things with old cars…
Louis
I Love Ed Sheeran
The new sensor is non genuine cheap aftermarket. Bosch only imho but shouldn't matter for post cat.
Polynesian
It’s good to be a car weirdo. All the “normal” people must be weird in another way, which has to be worse!
I’ve been there with the birdshit thing. How’s this for depth and impact?
Yarp
  Clio 182, E46 M3
I made it harder than it needed to be 😂
Iike everything, once you’ve done it once it’s a piece of piss to do it again
I’ll drop you a message with some tips (won’t be tonight though)
Legend, cheers!
No rush. I’ve been meaning to do it since about 2022. Probs won’t get round to it until 2028 at the earliest.
