182 cup spoiler brake light repair - options for sources? + issue with main rear light unit
Car  BG 182 FF
Hi all,
The top level brake light on my car's gone out and been marked as a major in the MOT. Slightly peeved since I'd seen another Clio near me only get an advisory for the same issue but realistically I suppose it should be done. Those who've had this issue occur on their 182s with the Cup spoiler will know the torturous endeavour that is sourcing a new one - I believe the part was only used on the 182 Cups and the Mk1 Megane Coupe and isn't manufactured by Renault any more. Breakers seem to want to sell the whole spoiler for £100+ usually, which I don't much like the sound of if there are cheaper options.
I've heard of repairing the actual unit itself by cleaning connectors or replacing the LED strip - if the former doesn't work, what cheaper light unit could I buy to harvest the strip from? I think I've read the standard Mk2/3 light works for this purpose but not sure. If there are any good compatible sub-£30 alternatives I'd be glad to hear about them.
Also, while I'm here... another failure point was that the back-left position light dims ever so slightly when the indicator illuminates. Anyone had this before or know how to begin diagnosing the issue? I would've thought it's a problem with power supply to the actual unit rather than a bulb given the symptoms but maybe I'm wrong.
TIA for both.
JMRS make replacement strips
Mine does this about every 12 months, have to take the unit apart and clean up the contacts. Some say the earth point causes the same fault by my earths were all mint.
My reading's also led me to believe the earth's the usual culprit; good to know to take a look at the other contacts too though, thanks. I'll check it over once I can actually get the plastic fastener thing in the boot to budge. Is there a tool for this or something, or is it just a case of trying harder?
The black nut? Just un twists by hand, the lamp casing just has plastic clips that feels like they will snap because Renault but you don't need any tools from memory :)
The top brake light pried out with a thin plastic blade much more easily than the guide on this forum had me fear, but it doesnt pull out of the spoiler far enough for me to access the connector clip. No Torx screwdrivers in the house somehow so that's on the shopping list before detaching the spoiler.
Managed it with a pair of pliers and the acceptance that the nut wouldn't end in the same shape it started as. The procedure was easy after getting that first 10° of rotation.
All pins in the connector for the light unit look pretty good, but the bulb contacts have a little black to the bottom of them, so I expect it'll be a case of either filing them or getting a new bulb at worst.
Update, pulled out the top light a little more which provided enough room to jam a longish flathead screwdriver in from the left and lever the connector tab up with ~15 mins of fiddling and luck. Light's out now and the resistors on the PCB are totally fucked, one broke off with zero effort, so awaiting a new one from JMRS now. £28 and free postage so probably about the same as cannibalising an eBay unit but likely more trustworthy.
Position light bulb had some faint tinting on the inside top, but a spare replacement bulb had the same blinking issue, so contacts are probably the answer.
Do you have a link for the brake light as im currently looking for one and cant find it through any of jmrs pages.
So I don't know if I did something wrong in the purchasing process but after paying I never received the part nor heard back from JMRS so at present I can only advise against buying from them. I might message again to follow up but for now I've taped over where the light was and will probably just put it for the MOT like that, since it's only a major defect if it's present but faulty, not if it's missing.
Right cheers i guess I'll keep looking on marketplace for something to pop up and I mean I'm the same only for MOT purposes am i bothered about it, funny mine got an mot just before I bought it with no mention of it but has never worked since I've owned it.
I’m no electrician, but how hard would this take to replicate, surely it’s just a narrow pcb with LED’s and a few chips soldered to it?
Just LEDs and resistors as far as i can see yeah. Problems are that I don't think PCBs are readily available and i don't know what resistors to be using since the old ones are so corroded the casing isn't present.
Again definitely not my skill set but I watch a lot of repair videos and their usual sponsor is pcbway, if someone could mock something up I’m sure they could create it 👍
If anyone is having an issue with this a cheap fix I ended up doing on mine is using these cheap little led strips then just sticking them to the part where the little bulbs used to be even lined up pretty well with where the bulbs were then just wired it in. Just make sure full cover all the exposed wire which I did not at first blowing the fuse which also is the fuse for the dash and other brake lights which was a fun drive to and from work. Regardless worked a treat since I sorted that and for I think a fiver for 5 strips no doubt the easiest and cheapest fix to this common issue.
Finally sorted - bought a used non-Cup light in good condition on ebay for like £15 and swapped the strips. Once you've gotten into the sealed unit the swapping process is very easy, they have different connectors but these easily unclip or pull out of the PCB. Image for documentation purposes and the benefit of anyone finding this thread in future.
Finally sorted - bought a used non-Cup light in good condition on ebay for like £15 and swapped the strips. Once you've gotten into the sealed unit the swapping process is very easy, they have different connectors but these easily unclip or pull out of the PCB. Image for documentation purposes and the benefit of anyone finding this thread in future.View attachment 1791329
That's handy, thank you.
I've recently bought the JMRS replacement board to sort out my cup spoiler light.
How did you pull apart the old unit?
Pretty easy once it's out of the spoiler, which I described in previous replies and needs a decent amount of patience. The PCB is only held in by metal clips around the main housing and some prongs on the inner clear plastic diffuser. Both are simple to get off.
Still doesn't work lol, multimeter confirms the new strip works but one of the prongs inside the plastic connector is nearly snapped (plus they're all oxidised). I'm having zero luck finding replacement connectors but have wires lying around so might have to replace it with those.
Well I had a test go at this. Read that it could be a pain in the ass to get the light out and the spoiler back on. Wanted to see how bad it was to do before I replaced the actual led board.
Light came out piece of piss. Old PCB came out fairly easy after fiddling with the metal clips.
Refitting spoiler a bit of a pain but doable without a second person.
But FML I cracked the light unit pushing it back into place so got to get another one now anyway.
So yea, if anyone has a 182 cup spoiler high brake light unit they want to get rid of, hit me up please 😂
uh oh 😶 i haven't tried refitting the unit yet and it never occurred to me that breakage could be an issue at that point... good luck with finding one, i think it's the same one as is on the mk1 megane coupe, if that helps at all
I think it's because it went in at a bit of an angle. I gave it a tap and it hit the lip on the edge.
Lesson learned for next time though!
I repaired mine for a fiver. See my Clio Projects thread. My damage was very similar to yours.
