Ph1 revival
  Ph1 track 172
Finally to close, here's a fun thing I've learned, early ph1s don't actually have a keyway in the crank sprocket. I am told that this is because they use a forged crank of another renault but dont know for sure. Annoylingly i had thrown my original one away (or into the rusty scrap metal pile) in favour of the keyed one, so will have to source another.
  Ph1 track 172
Also Also - (i wish you could edit posts) - has anyone seen a breather like this before? I has a completely flat bottom, no machined chanels what so ever, i assume this is part of a larger assembly? It also has no residual evidence of the channels in the rocker cover. I've basically just used it to mask up the breakther openning now so i guess its already ruined anyway.
Brigsy
  T.Turbo
I think that breather plate is a tessa one for coilpack relocation. Pms new style one is best,id go with that.
I also had one of the bolts deep in the sump round off. Drilled it in situ knackering the sump in the process, right carry on. If yours aint leaking, id leave it.
  Ph1 track 172
Someone threw it in when i bought some KTEC ITBs off them, IIRC they mentioned it was a Tessa one at the time. I was going to just get the PMS one when i get around to placing a big order.
And yeh, so far I've gone for, sump not leaking, leave it on. My only fear is when I had to drill out 5 headbolts, i tried very hard to get all the swarf out when a magnet and i didnt see any evidence of any getting further than the head, but there is a chance some ended up in the sump, thought it was full of oil at the time so most should have come out when I drained it.
Tbh I'd happily buy a new sump as theyre pretty cheap on PMS, i just dont want to try and cut the existing one off and do more damage out vanity.
Old one didnt clean up too bad with the wire brush, i will leave for now.
  Ph1 track 172
Dropped the subframe in situe - wasnt the easiest job as the was is basically up against the wall of the garage - left the hubs and brakes in situe. Need to actually work out how to get hte car our of the garage in this state... will be interesting.
Stripping the old paint off the subframe - i did it with a paintbrush and it was chipped and looking a bit sorry so thought it could do with being redone.
Greenhouse has basically become my spray booth at the moment. Subframe after a lick of paint.
Need to do the underside this week.
Another little job was to wrap the exhaust - I bought a 182 manifold a while ago and like the idea of not cooking my starter motor on track.
Before:
After: (quite an unpleasant job to be honest)
That is all for this week kids!
Head is still at the machine shop - should be back next week so hopefully i can get my engine build back up sometime in the coming month.
I also have realised that i neeed to get rid of the cams i have - i bought 422s cheap but it sounds like i need to get new pistons to make them work, perhaps 421s are the only ones that that will work with a standard bottom end.
  Ph1 track 172
Not really an update, just a photo dump
Also had my driveshafts rebuilt by Peter Withers, not sure if he uses the forum or what his name is on here but hit him up on facebook if you're looking for a refresh.
And my efforts to convince my dad to sell his vintage bike for more room has failed... He bought another one, so now even less space in the garage.
  Ph1 track 172
Got some new toys!!
Vernier cam pulleys
Lightened flywheel
Lightweight crank aux pulley
lightweight water pump pulley
PMS breather plate
the list goes on - it was not a cheap order in total.
the build is always the most fun part!
Having the silly desire not to leave my subframe outside in the elements while looking so fresh, ultimately silly since it will go back under the car where it will live afterwards...
cylinder head has been ported/polished by M.S.Customs - again not sure if theyre on this forum but find them on facebook if you want work done! they recut the valve seats, modified the intake/exhaust ports, checked all the tolerances, pressure tested, gave it a skim and rebuild the head with Wossner valves and uprated cat cam springs (and new stem seals). Very happy with the result.
I hate putting heads on! so much at stake! and the need for so much force while trying to stay to delicate precision...
but its on! time will tell if on correctly.
I found out the other day that the cams i have ordered (5503421) are on back order and wont arrive for another month. So my build has basically ground to a hault.
in my bordom i decided to just test fit a few bits i had lying around to see what the engine would look like once complete. great use of time if you ask me!
realised then that the second hand hoses i bought were dirty...
And finally, in case you wondered how i leave my engine out at night with the newly refurbished head exposed... ask no more.
After this a few bin bags over the top and just tape it all up!
chazza114
How much was the driveshaft refresh? Mine are looking quite tired now and could do with some sprucing up.
Also make sure the clutch you're fitting works with the lightened flywheel. I made the mistake of fitting a stock clutch the first time around, which wouldn't engage any of the gears. Ended up going with a Sachs Performance clutch kit as they have more clamping force than standard.
  Ph1 track 172
oh wow, thanks for the heads up, i hadnt considered at at all! this is an engine dynamics one, didnt say anywhere that it wouldnt work with the standard clutch but will check.
Drivesaft refurb was £250 - quite steep considering the price of pattern parts but was all proper Renault components used.
chazza114
Might be worth sending ED an email to check, means you'd avoid pulling the engine back out like I had to do lol
£250 doesn't seem so bad considering you can't buy the ph1 shafts anywhere now!
  Ph1 track 172
This was my thinking! I read so much about people getting the wrong lengths with pattern parts and having knocking issues. Especially for ph1s as it sounds like they changed every dimension a tiny amount just to make sure the ph2 parts wouldnt quite work right!
Having such a headache with the fact that the ph1 had such a limited run that lots of suppliers just lump them in with the ph2s even though the parts wont work!
On a better note - checked the ED website and it specifically says that it will work with a standard clutch. Didnt plan on updating given the power i am aiming for.
mintno1
  Ph1 172 / Mk1 Valver
@Struggler Good to see the Ph1 getting some love :love: Front subframe all looks great, it's on my list of things to do along with the rear beam, any tips? I was going to get it powder coated along with the wishbones but someone else said raptor the subframe, not in any rush, it doesn't have an MOT currently and I SORN'd it for the Winter yesterday, but am going to come up with a plan!
  Ph1 track 172
I think my one tip would be to remove the pivot bolt on each side rather than removing the bracket from the body. This way you can avoid the risk of the captive nut just spinning. Once that happens it becomes a massive headache. Downside of that is you need ot drop the fuel tank a little one side to get a bolt out but still not remotely difficult. I managed it all on my own.
I was going to go down the powdercoating route but read some stories about peoples cracking and chipping almost immediately. Not that this wont happen with painting but its pretty cheap to paint.
Also recommend the axle spacers, really imrpoves the stance.
Update!
I've not really updated this in a while. The problem i have is the cams are still on backorder so I'm really just spending my time getting other bits and bobs done.
Fitted the ECU to the shock down and the catch can. Im running the PMS gearbox mount so theres really not going to be anything else to mount to in the area. You might also notice that I've used some spacers on the catch can. I put brakeline pass through right in the middle of this section of firewall before realising i wanted to put hte can there. Rather than move it ive spaced the can out on top. restricts access to the brake line which isnt ideal but its using M8 bolts so not going anywhere. Might change later but will involve draining the brake system.
Also its not as wonky as it looks! its just the body shape makes it look so ;).
The Gen90 ECU im running is designed only for the ph2s, and Renault made the wonderful decision to completely change the engine loom with the facelift. So you had the wonderful task of repinning all of the ECU to match. Horrible job that im not 100% sure ive done correctly.
Then went about hacking some connectors off the loom to tidy it up. ITBs cannot run an idle control valve or MAPs sensor so they're gone. Also not running VVT so lopped off the VVT solenoid connector. Left some length on the wire in case i change my mind and want to put it back on!
All capped off!
Another wonderful ph2 only design - the ITBs run a throttle position sensor, same as the ph1 but a different unit with its own wiring. KTEC supply an addaptor for the ph2 throttlebody, which again is obviosuly not compatible with the ph1 loom.
So cut that off and hard wired it into my engine loom
Then just started rewrapping the loom to tidy it all up. probably not worth doing at the moment since i dont know the final routing for the wiring until the engine goes back in, but makes it look a bit tidier!
Thats all for now! hopefully the cams come next week and i can get the engine rebuilt and back in!!
Also those bolts for the PMS susension top mounts are rusty... thats going to bug me.
KitsonRis
I did have a lot of help from others on here doing this! But my argument was if I can do it anyone one can 🤣
I hated doing the ECU changes as that was an expensive piece of kit that I didn’t want to ruin!
Oh might want to chuck some sacrificial spark plugs in when you start it for the first time. My Gen90 was defaulting to 100% throttle as a base map and ruined the spark plugs from over fuelling. I’m sure I mentioned this in my thread.
  Ph1 track 172
Oh thats interesting, i will clean up my old plugs and reuse them to begin with.
I am really not sure what map is on the gen90 I have. It is second hand from a 182 but i got the ITB kit inc injectors all at once so maybe what is on there will at least fire up.
Thinking about it, now that ive repinned i should be able to power it up, I'm unclear on if the gen90 runs an imobiliser, which obviously might be quite unhappy when it picks up my key in the ignition.
I should probably invest in the wire and software so i can do some of the software side.
KitsonRis
If it’s second hand and got a map on it then it might run better than mine did on start up.
Isn’t the immobiliser on a different ECU behind the gear stick? I never did anything about an immobiliser on mine
  Ph1 track 172
Behind?
There is (what i think is) the airbag module in front of the shifter, bolted to the floor, but thats long gone.
Im pretty sure there is another computer behind the dash somewhere near the fuse box. Maybe its in here.
Will stick the key in next week and see what the light does.
KitsonRis
Oh maybe was thinking of the airbag module. I knew there was something behind it!
Yeah I wouldn’t worry too much about the immobiliser, mine seemed to still work and I didn’t do anything and I’m a proper ham fisted idiot when it comes to fixing things.
  172 Ph1
No , the immobiliser is part of the UCH box , not a separate ecu.
  172 Ph1
Yes that’s correct , the black box that all the loom connections plug into where you have circled.
Also great to see a PH1 receiving some much cared for love.
Nice 👌🏻
  Ph1 track 172
So, its been a while since I posted hasn't it!
I had a nice timing plan for the build set out with the engine being back in the car before winter. Got to ordering all the parts to make that happen, then... CatCams.... Placed my order through in October with plenty of time and sunlight and nice weather left of the year but when following up was told they needed to be specially made and would take 6 weeks, which ground everything to a halt a little but I found the above loom work to get done in the meantime.
Unfortunately the delays kept coming and I started to panic that the engine was going to be left outside over winter without even the rocker cover on. Had I known I would have kept the head inside and waited until spring, the engine stood outside per the last image I shared albeit with a tarp around it.
Anyway, nearly 12 weeks after ordering, literally when the days are at their shortest and we are down to single figures, this finally arrives!
Not wanting the open engine to be outside a second more than it needs to I went down to Essex to get the engine built up thinking hopefully if I start at 8am I can get it all done before the light fades.
Nice little pile of toys to fit.
Lifters and followers fitted followed by cams with lots of assembly lube
This stuff is the bane of my existence. Knowing that putting on too little risks an oil leak that can only be solved by removing all of the timing etc but too much risks some silicone coming off and clogging the oil pickup and destroying the engine makes it a task fraught with anxiety, especially for a first time... and it gets f**king everywhere!
Did I put on too little? too much? time will tell but only a very small bead came out the sides so I am hoping I fully Goldilocks'd it.
Running all the bolts down ruined my lovely painting... oh well, not time to dwell, it still looks good from afar.
See! looks fine. Also you can see how much gasket stuff came out the sides, if someone knows for a fact that I've screwed up royally, please let me know... gently.
Then it was just a case of putting the cambelt on and timing it up.
This was... interesting, and I'm a little worried the timing may be every so slightly out. You see some videos of people just putting the timing tool in with a finger and it sliding gracefully left to right. Mine does, it goes in with a push, but needs a push. We are still talking one handed push, but full palm not fingers. Most sources suggest that this is fine and I put some of it down to the aftermarket cams and springs having a lot of overlap at TDC, even with no cam pulleys installed at all the cams didn't want to sit perfectly level as the springs were under some compression at TDC.
Again - and wizards want to chip in please do.
Anyway, engine is a lot more built up and sealed now for the winter and I tried to do the best job possible as winter prep.
This is clingfilm, tarp, and clingfilm again to there are any pockets to hold water. I almost want to string some Christmas lights around it and call it festive.
As always, thanks for reading, I'm not sure I'm going to do anymore now until the spring but we can see how the weather looks. I can more or less put the engine back in the car now, we will see.
  Ph1 track 172
Hmm, so I appear to have made the mistake of following the video by James Stone as a guide... Not the first person on this forum to do this it would appear.
I've used the silicone he used in the vid SI5890.
Now it would seem I'm in the difficult position of deciding if i scrape it off and start again or risk it. I am leaning towards the latter at the moment as I did head the warning and use sparingly.
Brigsy
  T.Turbo
Unfortunately people use/recommed the wrong stuff for the cam covers. Id scrape it off and use the correct anaerobic flange sealant to avoid any future headaches. If a bit of sealant comes off and blocks an oil gallery or oilpump strainer, be engine rebuild.
Mertin
  Ph1 172&Ph2 172 Cup
Great build thread and good to see another Phase 1. I'm going through some engine upgrades just now and similar to yourself, pulled the engine out the car so I could work on it properly and have everything cleaned up. ITB's and ARP rod bolts turned into cams also which meant timing belt kit and while sump was off, reseal no.1 main bearing cap and do the crank seal also.
One question, have you fitted ARP rod bolts? I see you mentioned not disturbing the sump. These get mentioned as a weak point on these engines and especially if going for higher rev's. Would be a shame to go to all that top end work and neglect the bottom end. That was the main reason for pulling my engine, to make it easier to fit the bolts and I also wanted to address the common oil leaks. No.1 main bearing cap re-seal. I only had a slight weep
  Ph1 track 172
I think you actually posted on my other tread @Mertin re ARP bolts. I initially was going to leave the bottom end alone but have decided now that I am going to drop the sump and replace the bolts. Potentially the oil pump at the same time as this appears to help the low oil pressure issue.
Unfortunately that sump is not going to come off easily, hence initial plan to leave it be. The move difficult bolt to get to, where you have to thread the bit down a hole by the flywheel has some damage and didn't want to come off. I realise now you get much better access with the flywheel off so will attack it from that direction when I get round to borrowing my mates crane (currently on the stand with the flywheel still on. Will inspect the main bearing for leakage also. Worst case scenario is come in from the side with a grinder to cut the bolt head off and buying a new sump pan.
I don't suppose you have detailed the no.1 main bearing re-seal and other common leak points, i should inspect those once i drop the sump.
Mertin
  Ph1 172&Ph2 172 Cup
Ah, that makes sense now. I didnt even twig at the time. I haven't got a thread as such but just picked up all the info from various posts on here. Feel free to drop me a DM with any queries, just literally done the no.1 main last week.
I had noticed a post on AW Motorworks facebook page mentioning the front crank seal housing leak & also the part number for the gasket. Im going to do this one also for all the cost, and like you say I had just been looking at the dci oil pump of PMS site last week and reckon I'll throw one in while everythings in bits.
Mertin
  Ph1 172&Ph2 172 Cup
Link doesnt seem to have worked but was posted on 12th November if you want to look back. I also have a few screenshots from the manual that others had posted on here with the method for doing the No.1 main that I can send if you haven't came across them on here while searching
  Ph1 track 172
tiny update mainly to move my project thread to the top of the list, make sure you dont forget about me init!
Really I'm just waiting for the weather to improve before getting back to work.
Decided I'm going to do a bit of work on the bottom end. Ideally I would have done this before I rebuilt the top end but we live and learn. Started collecting some new bits to do so.
I have a rounded bolt on the sump, right up by the gearbox bellhousing so not completely sure how I'm going to get it out. It looks like there is access from the side with the flywheel off so it may be a case of angle grind from the side, taking the sump with it. Hence the new sump. On top of that there is the bigger oil pump from the megane and some new big end bearings, not sure if these need doing but given the price and the engine being open anyway it seemed sensible. Some ARP bolts too.
Shocks are also a little on the scabby side, not considering replacing them until i read some threads about refurbing. I never took any better pictures of them but they're about 15 years old now, springs are equally scabby.
Ended up getting them shot blasted, re-coated, new springs and fully serviced for £200 which im very happy with. I know people have mixed opinions on the gaz ghas but they're fine for my skill level and for the cost.
Like i say, as soon as I have a free weekend and the weather looks up a little i will throw all of this back together and get the engine back in the car. Fingers crossed not too long now.
Ben perry
  Clio 172 cup
Nice progress I have gaz on my 182 they don’t need a refurb but are scabby as f and I want to tidy them up bad!!! and I have to say I can’t fault them on track.. little gross on English roads tho 😂😂
  Ph1 track 172
Well the servicing costs a very reasonable, especially if you pay cash and drop them off/pick them up yourself!
  Ph1 track 172
Right! Reasonable update this time!
Firstly - front suspension back on and looking good! I need to get some kind of cleaner for my arches to make them sparkle a bit more! any suggestions would be great.
I was then hitting a bit of a wall with the build. I new I needed to drop the sump after I had to drill half the headbolts out and managed to get some swarf down the oil return, then the "while you're there" fairies came flying in telling me to get ARP bolts and a new oil pump while I was at it.
Annoyingly, the sump bolt behind the flywheel had completed rounded, and I couldn't get any access to it while the flywheel was on and the engine was on a stand.
Eventually managed to borrow one and down she came.
And this was the offending bolt
I had bought a megane oil pump which required some modification to the sump, thought better of doing it to my only sump so bought another one. This meant this sump was surplus to requirement, so just went at it from the side with an angle grinder. Actually quite easy once you remember that aluminium doesn't spark like steel does, so you know when you're hitting the bolt you're trying to cut.
Ended up having to cut 5 off in total. bought some new allen head bolts to replace them all. Photo from my dad of me grinding (inc depressingly growing bald patch :cry:)
Only photo I took of my modded new sump, this ended up being not nearly enough to clear the new pump.
So, sump off I set about changing the big end bearings. I'm quite happy with how the old ones looked, nothing you can feel with a fingernail meaning the 90k miles its done have been quite kind to her. This is cylinder 4
Then I realised, that if the old ones come out perfectly OK my intervention can only have introduced more potential for failure with no benefit (assuming best case scenario is new bearings are OK like they were before). Oh well, not time to think just need to crack on.
Crank journal for reference, this looks a bit worse than it is, its perfectly smooth to the touch.
I also wish the bearing had a tab on them. For lateral positioning and to be confident that you have them in the correct location. This is the first time I've done bottom ends so more error proofing would be preferred.
My parts bin special early 172 let me down again, the windage tray didn't fit the new pump, thankfully I found one on ebay for very cheap that looked to be correct. I'd heard of other ph1 owners having this problem so was already prepped for it.
Run out of photo space, pt2 incoming
  Ph1 track 172
New oil pump installed, it looks huge by comparison, i had to go back and cut more of the sump off, but I didnt take any pictures.
Very close to the crank too, but Nick from PMS and members on here assured me this was OK. Also ARP bolts were installed when I put the new big end bearings in.
And as far as I was concerned, that was the engine rebuild complete. I put the crank back on with new bolts and a new seal, filled her with oil and cranked it with a drill and the oil filter off until it came pissing out, refitted the oil filter and pumped again for a while to get the oil circulated, then it was an early night ready for a full day on Saturday.
7am start, much to my neighbours delight I'm sure, was to get the car out the garage. Subframe is in the shed so basically chained to crank to the tow eye and lifted the front end and rolled it. Probably not great for the tow eye but I have confidence in the material properties of steel. Front end isn't have heavy without the engine or subframe.
Then it was a case of redressing the engine with the gearbox. Starting with the new TTV racing flywheel.
Gearbox and starter motor - person I bought it off had put some gold heat proofing on it, between this and the heat wrap on the exhaust I'm hoping I dont need the heat shield as I cant find it.
My nice new ported head revealed for the first time
And finally the exhaust - the exhaust I hear you say?? Yes. My plan was to basically put the engine on the floor, and lift the car over the top, so having the exhaust in installed should be OK. I like this picture a lot, though I wish I had taken the bin bag out of the diff first.
Lifting car over the top of the engine...
And lifting the engine in :). All went better than expected, only issue was that I didn't have the front lifting eye so had to lift around the head, this had to effect of tiling the engine forward so the exhaust was hitting the exhaust heat shield. Oh well, it bends.
First time I had seen my new refurbished shafts as I hadn't bothered unwrapping them. Very happy with the result.
Will continue the post when I get the last photo dump from my dad who was an eager observer and occasional helper all day.
  Ph1 track 172
so with some updates from photos from my helper (shout out to my parents for letting me use their garage for my build). Love that all photos taken by my dad are in landscape.
nice candid once engine was in.
Subframe out and lined up with the car.
Followed by the wheels and putting it back on the ground. And for the first time in over 2 years, the engine was actually in.
Handywork being inspected by dear pa.
I had more or less insinuated that I was going to completely clear my parents spare room of car parts, so from there just kept on fitting things until I ran out of light and documenting any issues I found along the way.
Then even some bodywork went on - so it resembled a car for the first time in about 3 years!
Bodywork is very tatty - I need to decide at some point if I want to get a body shop to look at it and get some bits repainted etc or if I want to just accept its a track car and its pointless making it look too pristine.
That's basically when the weather started to turn and the light fade, it was gone 4pm at this point and my back was not in a happy place. So car got put to bed, very different to how she woke up.
Closing pic from my dads phone - I'm over the moon with the progress that was made today. Fitted the linkage also which I didnt take any pictures of but this is me fiddling with the gear shifter. If there are tips to align this perfectly, please let me know. I think the exhaust bashing the head shield during installation might have dented the shield as the linkage was hitting the shield a lot.
And that was it! jobs left include:
  • Finish wiring and plugging things in - need to find the best routing for wires so they done get snagged/melted
  • Finish fitting the ITBs - I couldn't get bolts in the bottom of the manifold, the m8 cap heads I was using seemed to have too large an head diameter. Need to get some smaller head bolts potentially?
  • Make a new centre heat shield as mine ripped up removing then refit the exhaust.
Then I should all being well be able to start the engine! I'm hoping in a week or two I can give that a go. There are other jobs that need doing but getting it running is my main target for now.
Anyway, thanks for reading kids!
