Clio 182 RB
colesy
  172 182 197 E61 530D
Why would you not just take it to EFI/Engine Dynamics?
Someone that knows what they're doing
To be fair Andy helped develop the gen90 and when I had mine done there he said him and Chris at Efi talk pretty much everyday.
Ant1
Brembo! Brembo! Brembo!
One thing i can’t find any info on is radiator support.
Given i’m still have the stock rad/condenser fitted what are people doing? Probably not the best idea leaving them to flap about.
Jobs left to do.
- Refit arch liners
- Cut section out of bumper upper plastic to fit around itbs
- Fit bonnet latches
- Rad support?
- Road test
- Map
Once above is done i will fit a set of camber bolts and get alignment booked in.
Yarp
  182 Turbo, E46 M3
The rad pipes go fairly solid when it’s hot. It’ll be reet, they’ll hold it still enough.
They dissolved a decade ago on most clios so you’ll be no different to most.
Ant1
So close to being finished!
Klumpy Dumpy
Try and see if you can bend that AC line away from the filter Ant
Micro vibrations will rub a hole straight through that if the heat from the pipe doesn't
Ant1
I’m going to play with the bracket when i fit the aeros on Sunday. Only needs a cm or so.
Ant1
All set ready to go.
Just finished bleeding coolant, bonnet pins fitted and given a check over after short drive.
ITBs are noisy in car even when casually driving along 😂
Big day tomorrow - Fingers crossed it holds together.
If all goes well i’ll get the aircon regassed at weekend and give the bay a clean. Need to figure out a breather tank solution also. Don’t want to spend mega money and I would like it hidden away.
Been waiting to fit number plate light 😝 Finally got the chance today.
Ant1
What do we reckon power wise then?
200/210/215bhp?
I’m reckon 206bhp 😂
Brigsy
  T.Turbo
Sounds well, just seen a vid of it on the dyno
ex-Chinese Dave
  172 Cup
View attachment 1766343View attachment 1766344View attachment 1766345View attachment 1766346
Looks very very clean....the best colour, too (y)
Ant1
Alternator has shat itself so if anyone knows of a good replacement for sale or what new alternatives?
Ant1
Alternator being fitted on Saturday.
Got a new Valeo so that will do.
Insurance sorted via Greenlight. Everything declared £360 for the year.
Can’t complain.
Looking forward to using it properly next week!
List of bits I want to sort in coming weeks.
- Airbags switched back on
- Radio code
- Fit stripes
- Maybe put 182 wheels back on
Ant1
New alternator fitted today so that’s all the niggles sorted.
Haven’t been for a proper drive since all the work so as the weather was decent today, seemed a good day for a trip out.
Really pleased! Car is noticeably quicker, far better engine response and it just pulls right upto the limiter.
Diff works well, probably a overkill for my use however i was all ready balls deep so why not?
Did i mention the noise? Oh the noise. It’s glorious.
It’s not the quickest hot hatch, far from it. However it’s so entertaining and I can’t think of another hot hatch i would rather drive for the money.
I said to the wife - Show me another hot hatch that drives, sounds and looks like this for what it owes me.
Great all rounder.
Brigsy
  T.Turbo
Good to hear its sorted. What version did you use in the end? Im on v176, installed years ago and stuck with it as pretty stable.
Ant1
V157. Had a good poke around and it works OK.
Now i have laptop/hardware/clip it should be set for life.
If anyone ever needs a copy of V157 in future i have software and what appears to be a genuine reg key.
PerthRS
  Clio 182 CUP
Always been interested in getting my hands on clip.
Near on impossible to get genuine hardware down here. I'm assuming you need a laptop with windows XP along with software and hardware interface?
I've seen plenty of listings on Temu/Alibaba etc for the hardware. Do these work?
