Rear Beam stiffening
Jakeboy
  Clio Trophy
In process of doing a rear end refurb and getting rear beam sand blasted and powder coated. Debating while beam is off fitting an axle stiffening kit. Thinking it will essentially have effect similar to a stiffer ARB. 182 trophy, fast road, standard shocks, fully polly bushed.
Matt Cup
  Iceberg 172 Cup
I’ve seen posts where if you aren’t allowed to use a rarb then axle stiffening is a good alternative.
JamesBryan
Could be wrong, but part of the kit does away with the factory spring perch.
So unless you have a full coilover on the rear, you wouldn't be able to use that bit.
