Clio 182 RB
Ant1
Brembo! Brembo! Brembo!
Always been interested in getting my hands on clip.
Near on impossible to get genuine hardware down here. I'm assuming you need a laptop with windows XP along with software and hardware interface?
I've seen plenty of listings on Temu/Alibaba etc for the hardware. Do these work?
Aye I purchased a good used laptop for £36 delivered off ebay. Runs really well with good battery.
Hardware is a used chinnese rip off with cracked software. £55 delivered.
Much cheaper outlay than RStuner but does require more than braincell to setup and use.
PerthRS
  Clio 182 CUP
Sweet. Thanks for that.
May look into this.
Even if it's cracked. Do you still need the genuine reg key?
I haven't really dived deep into the rstuner (which I have on hand).
Im assuming that does most things that clip does?
Ant1
Pros and cons to both. In all honesty i wanted the cheapest solution to sorting airbags.
Ant1
Tempted to buy this just for the seats and flip the car 😆 Not sure i can be arsed with the hassle.
Yarp
  182 Turbo, E46 M3
Makes sense tbh. At 3k with those seats it’s a steal. Quick tidy up and you’d probably get most of that back too.
Ant1
Decided to jack the car up and check for any issues now it has done 100 miles.
Little surprised to see both drive shafts outer boots twisted and split. They aren't that old and covered minimal miles. Grease f**king everywhere.
OS has a some play in the joint so decided to lump it and fit a new set. I’ll keep the removed set for a rebuild at a later date.
Good start upon opening box 😏😂 good job i have some spares stashed away.
Took my time fitting so boots didn’t get damaged.
Slight weep coming from between box and engine so will recheck in a few months.
Next job to sort is the handling. Although very good it’s not a patch on the 172 cup i refreshed earlier in the year.
Rolls a bit too much pushing on and not as sharp.
All bushes/arms/shocks have been replaced within last few years. My old Cup had Konis/solid topmounts/camber bolts/purple arb bushes so naturally it would do.
Shame Konis aren’t available so probably will be looking at B14s. Will keep an eye on prices over Xmas.
Steering wheel size is pissing me right off so a decent 330mm replacement will be replacing it shortly.
Ant1
Gave it a wash today. Noticed windscreen steaming up over night. Checked under back seats and found a small amount of water.
So assuming rear bung by clusters need sealing which will hopefully sort the problem. Will stick the rear bench on radiator to dry when sorted.
Other than needing a uprated dogbone mount the cars performing well. Mpg is pretty shocking 😂 but to be expected.
Ant1
Sorted the rear bungs a few days ago. Stripped rear seats and boot liner out as soaked to dry.
Today was ice on the car and pleased to see no more condensation on windscreen inside car.
Ant1
Fitted polybush dogbone mount and new upper engine mount.
Old upper mount knackered.
Lubed (silicone spray) throttle return springs, moved accelerator pedal as far right as possible due to foot catching, and adjusted idle.
Such a difference to drive:)
Ant1
Nothing to update on the Clio except smiles.
Now has a friend….. it was cheap enough to warrant the purchase to see what it is like before i go down the R26R route or perhaps a MK3 Trophy R.
Ant1
Fired up the Clio for 20 mins today to get everything moving as i haven’t used it since acquiring the Megane.
Good timing really as the roads are proper s**t so parking up the Clio is a bonus.
Cleaned and hoovered as today is the only dry day since Xmas.
Still debating fitting 182 alloys as i can use the money from the turinis to fund brakes/belts on Megane.
Ant1
Due to pending eye watering bill incoming for Porsche, i will be advertising this at the weekend.
f**king devastated tbh but the Porsche will always be the one i want so i will have to swallow the man pill and get on with it.
If anyones interested get in touch.
Bleu
Same price as you bought it for, right?
  Clio 182 cup
Se instaló un soporte dogbone de polybush y un nuevo soporte de motor superior.
El viejo monte superior estaba destrozado.
Resortes de retorno del acelerador lubricados (spray de silicona), pedal del acelerador movido lo más a la derecha posible debido al enganche del pie y ralentí ajustado.
Qué diferencia para conducir:)
View attachment 1771165View attachment 1771166
hola, que marca es el soporte nuevo que compraste ??? precio ??? gracias !!!
