172 Cup OEM+
PerthRS
  Clio 182 CUP
From what I've read. With the right combination (197cams+7-8 inlet advance or Grp-N timing on standard cams) RS2's tend to sacrifice the peak torque figure, but will flatten and extended the torque over a much wider range.
Typically a standard f4r 730-738 makes peak torque around 5000-5300rpm. An RS2 equipped unit will make close to peak torque from 2500 to 6500. Though this is probably tuner dependent.
It is also advised to change out to 197/200 or 225 injectors due to duty cycle limitations on standard units.
ARP rod bolts definitely wouldn't hurt either.
I've heard the RS2 doesn't agree well with some off the shelf cams. As the inlet was designed to maximise the internally standard engine.
Got a RS2 sitting in the garage waiting in the wind. So would like to hear from people and their past experiences.
bowen86
Put in some time this weekend on the JMS Inlet.
The manifold looked like it was painted with a brush, so I started to strip it.
Under the thick black was thick red. FML.
It beat me and I've dropped it for vapor blasting.
The aluminium which was anodised blue, which isn't the worst colour considering the colour of the car, but it wasn't for me.
@frayz came through with the great idea of applying some bleach to remove the colour.
Voila
Trumpet panel had the same treatment.
Needs more work, but you get the idea.
In terms of what's needed or what I plan to add with the RS2 inlet. I'm in conversation with James who made and has the RS inlet on his Clio. At the very minimum a 182 Manifold and map.
bowen86
Bit of an update.
Pre vapour blasting.
And done...
Then I spent a few hours yesterday plumbing it all in. There are no fitting guides out there, that I could find anyway, and although pretty straight forward the vac line to brake booster had me stumped for a little bit. Also, the bolts on the bottom of the inlet... What the actual f**k. Dislocated my wrists getting them done.
And fitted.
Few bits need tidying where I've had to free wires from conduit etc.
Apart from starting it and letting it idle, I've not driven it and won't REALLY drive it until it's ready for mapping.
bowen86
Gathering some parts to get the most out of the RS2 inlet.
First part, a 182 exhaust manifold which I've bought from @Louis it has a V band flange welded on the end, which I think will make it easier.
My question is "how do I get this to connect up to a 172 exhaust?"
My current exhaust is a Klarius(?) system which is a repo of a standard exhaust, as I was done with the drone from the KTEC resonated exhaust.
I'm thinking I need a sports cat/decat which has a vband at one end and a 'normal' flange at the other like this?
Send help.
MAXRUNDOWN
I'd ditch the pattern exhaust and get a fab shop to make something to fit, you can still have something quiet with a couple of decent boxes in it if that's your thing.
I've heard nothing but bad things about the Ktec cats too, they're cheap china rubbish that probably won't get you through a legit MOT
I had a magnaflow sports cat welded into my milltek downpipe, it was a while ago but I think the lad that does my fab work only charged me £40 to do it.
This is the cat I went with
bowen86
Been gathering parts the last month or so.
197 Cams
Cambelt kit
Camshaft nut and seal kit
Camshaft seals for gearbox end
Keyed Crankshaft pulley
Exhaust manifold gasket
Brembo HC Discs
DS2500 pads
7 degree timing tool
182 heat wrapped manifold
2118 speedlines from @colesy. These aren't to be fitted ASAP more a future plan.
Lastly, the JMS inlet sits increbily close to the bonnet catch bracket. So I took a bit off it.
Will be having the mechanical work done this month, fitting and timing cams are way out of my knowledge bracket. I'll send my ECU off for a base map before driving to Engine Dynamics for proper mapping.
bowen86
Cam Belt Kit, Keyed Bottom Pulley, 197 cams, 7 degree timing, aux belt, oil + filter, coolant, 182 Manifold, sports CAT and an MOT (no advisories) for good measure.
Phil at the Grange Service Station Cardiff put in a great shift.
I was expecting it to be super hard to drive it home, assuming it would cut out and run rough etc. But it was 'ok', I was expecting much worse.
Home now to remove the ECU, get that sent to Engine Dynamics for a base map so I can drive it there for a proper map.
bowen86
ECU off to Andy at ED.
Couldn't help but throw the 2118's on. Because no one has ever seen a Clio with 2118's on.
They won't be staying white. Off for a refurb and a change of colour.
The old airfilter for the RS2 inlet was hanging. So found a similar item.
I was speaking to Andy at Engine Dynamics who was uploading a base map to the ECU. Andy knew I was dropping 197 injectors in, however I was planning to drive to ED on standard injectors and a base map. Andy already had a 197 injector map, so suggested I fit them now.
Just waiting on the return of the ECU and I'll fire it up...
bowen86
No pictures or videos, but I took the Clio out for a little drive yesterday.
It's incredible. I didn't really know what to expect having never tuned and NA car before, but I was really surprised and impressed. It goes so well and the sound of the RS2 inlet, just amazing. Very pleased.
I've got a huge blow from the exhaust and I think I'm just going to pull the trigger on a PMS exhaust and sports cat. I've come this far with the Clio it I may aswell finish the job with a good exhaust.
bowen86
Took the trip to Engine Dynamics yesterday, stayed the night before as it's 4 hours each way and my booking was 9am this morning.
Turned up this morning to be met by Andy who's took me through the mapping process. Very knowledgeable guy and I felt very reassured, even if some of what he said went over my head.
I explained the base map was really good and the car felt really strong.
A few runs and a few tweaks and I left with a healthy 192hp and 145ft.lbs torque.
Andy explained and I could also tell the car sounded really healthy and wanted to continue to rev, but Andy advised limiting the Rev limit to 7400krpm.
The torque was the most noticeable thing to me on the motorway drive home. I've since taken in on a more spirited drive and it's fantastic.
On the long drive to ED and back it's become even more apparent I need a less droney exhaust. Also, you might notice in the photos I had the Speedline 2118s refurbished and fitted.
gez 172
  Defender 110
@bowen86 where did you get the Grp n timing tools from, please? 🙏
Or rather, how did you get the 7 degrees set locally? Currently building an engine and will be fitting 197 cams etc etc.
bowen86
That map looks perfect - such a linear power delivery.
Are you going to push for more power or happy with it for now?
Yeah, really pleased with it.
No more power. I just wanted to get the best out of the current hardware, I also don't want to start chasing a number. Next is some maintenance, some bushes and quality of life stuff.
Are we local? I have a 7 degree timing bar you can borrow.
gez 172
  Defender 110
I believe we are buddy. I’m just outside of Swansea. 🙌🏻
