Tin.tin
Clio 182
Hi Gents
Having an issue with coolant level dropping over 4-5 days, topping up around 250ml. Temp staying where it should be however & car runs as normal.
Had the car pressure tested at renotec as well as a local specialist. Both have reported no visible leaks, only a bit of coolant residue around thermostat housing flange & a bit around pipe from back of water pump.
Had thermostat done & flange vapour blasted not too long ago so that area was spotless initially.
Now seeing a new bit of residue around it, not a lot though. Which is odd considering no leaks from pressure test.
Im scratching my head as this a bit outside my comfort zone & both garages can’t say 100% what it is so a bit lost.
Any advice/recommendations would be greatly appreciated
