Another one - Sport yellow meg 250 cup.
Done well finding the turinis mate - seldom come up!
Steevs are a funny one - not a fan, but in satin black I think they look well
Cheers mate! The turinis were a random fb marketplace find. Lad said he had been struggling to sell them.
Agreed about the steevs, much better in full black than diamond cut.
Updates.
Done a few jobs last weekend ready for mapping on Sat at EfiParts. Oil and filter change, recirc blanking plate and regapped plugs to 0.6mm. No pics as was working fast and nearly cut the end of my finger off on a razor sharp edge on the inside of the aftermarket oil filter it had fitted when i grabbed it. I was expecting oil to be pissing all over but that was controlled, was claret pissing out of my finger instead!
Washed today and rinsed using my new di water vessel. Game changer.
Will update after mapping.
Thanks for reading!!
Updates.
Steady drive down to EfiParts for mapping on Sat. Quick catch up with Chris and the meg was straight on the dyno.
Strapped on and ready to go.
As i said in earlier posts, this had been mapped years ago by another tuner. Ive said previously that it did not really feel that good..seemed to go ok ish but was skeptical of the 325hp printout on stock turbo.
Had a couple of runs to see power on the original map. Suprisingly it made 311/361 on 2nd run but not the 325hp it had on the printout, which was ambitious for stock tuned engine with a couple of bolt ons.
As you can see the torque comes in hard and fast for a stock engine, and a bit too much boost pressure with 24psi in the mid range. It was also pulling a couple of degrees ignition timing in the mid range so not great overall. Other issues noted were no boost requested low down for some reason, then all the boost ramping in with throttle closing to try and reign it back in on spool, and 25psi requested all the way until 6000rpm. With it not being possible to make 25psi on a stock 15t turbo at 6000rpm, this made the ecu wind up the duty/pid right up on the closed loop boost control. Ecu does not like this and can cause drivability issues.
With it making 311hp, it was unlikely that it would make any more peak hp, but for engine longivity the torque needed smoothing/reducing as 350ft/lb is about max for stock 250 conrods. Last thing we wanted was a rod to exit the block on this.
Chris got to work and started from fresh with a new basemap. After a load of runs fine tuning it to get everything as good as expected it finished up at 311hp/348ft/lb.
Before lines in red, black lines for current map.
All the boost in the mid range originally.
One of many dyno pulls.
Its now safer, and much better response low down in the rpm range. It felt very hit and miss on the old map depending what rpm you hit the throttle. It feels the same each time you hit the throttle now and the exhaust note sounds totally different low down. Also launch control activated in 1st gear.
As usual great job from Chris. Drives much better overall.
Also whilst in the area popped by a local place for a quick pic. Im sure a few of you oldskoolers will recognise it from an early 2000's sitcom.
The Archer.
Looks very similar to how he did mine, ramping it in more gradually.
The previous map on mine was suppose to be 330bhp and 350lbft :ROFLMAO:. It’s laughable what people will spout.
same power, less stress (y) winning
All day long mate. No need for 24psi low down on stock turbo, basically flogging the nads off it. Current 21 psi ramping up in mid is much better.
Seen one the other day claiming 330hp on stock turbo :ROFLMAO:
Need to get mine over to Chris for a fresh map.
Supposedly makes 315bhp, so would be interesting to see if it is. Plus the cold start isn't great on it.
Get it booked in mate. Cold start is great on this now, much smoother and no hesitation.
Updates.
A local lad popped round in a 250 recently to buy our old forge intercooler. Had a private plate on his 250 that looked decent, asked if interested in selling and at the time answer was no. A couple of weeks later he messaged asking if we were interested in buying the plate as the car was for sale. A deal was struck and its been transferred over, and new plates fitted today. Welcome R55CUP to the fleet.
Took it out today and feels quick as fcuk on the Efi map. Brake dust is horrendous on the wheels after mapping/few sends recently, front wheels are brown. Needs a good wash! But not enough time today so can wait for another day.
Updates.
Had the 250 out at the weekend to custom code the rs monitor v1. Massive thanks to Turborenault members for doing the research Cossie1 for sharing the information and Mart for doing the business on the custom coding.
I modified a proscan Elm327 cable with switchable can h/can m so i could access the bic module via can multimedia to code.
I then spent all week scratching my head trying to get Ddt4all to work, using the megane r26 to test.
Im no stranger to getting obscure diagnostic programs to work but after installing 4x different versions, none seemed to work right on mk2 meg being honest, very unstable and not confidence inspiring. I even upgraded my diagnostic laptop to a modern lenovo thinkpad which made little difference to how the software ran.
New diag laptop representing.
I was going to use Renolink and modified an obd splitter lead to plug in my obdsx cable, however when i tried Ddt4all on the mk3 250 on sat, it worked absolutely fine which was suprising allowing the script to be written without issue.
Original screens on rs monitor below, this was a factory fitted option from new on ours. Basically a load of crap data apart from boost, ait and oil temp which were spread over 2 different pages.
Wrote the ecu with the custom coding using Ddt4all.
First page is filled with the useless info. I mean who actually looks at brake
pressure?! :LOL:
2nd page has the decent data thats worth looking at.
All the good data on one page, Boost (recalibrated to 2000mbar allow higher readings to suit current setup), Intake temp (now starts from 0-80deg, Oil temp and Water temp both scaled so optimal running temps in the middle of the gauge. Its actually worth using the rs monitor now to keep an eye on things, like an onboard scangauge. All works great, its a nice update.
Give it a quick run out to test all good. Needs a wash, wheels are pitted. Next weekends job.
Updates.
250 out for a few bits yesterday.
First job was to fit a Properfekt recirc valve. I had fitted a blanking plate before mapping and had noted the car flashing up spanner light for a split second on high rpm throttle lift/hitting rev limiter and throttle close. Basically the spanner light/check injection flagged so briefly, i had to record the dials on my rayban meta glasses to freeze the frame to see what was going on.
I datalogged the car as it was with blanking plate a while ago and noted when throttle close at high rpm (5500rpm+), the pre throttle boost sensor would spike 3050mbar for a split second which triggered DF0004. As it was intermittent, spanner/eml did not store permanently so was only lingering in the background.
Datalog below showing gas pedal position zero (light blue) but 3054mbar spike on boost sensor (red trace).
After emails with Chris it was agreed that it could be due to no recirc fitted/blanking plate, with the boost spiking pre throttle body with throttle closed, with hard cut rev limiter also having an antilag kind of effect. Chris said he usually sees around 2500mbar spike with throttle close on the stock 15t turbo.
So with this in mind i looked at options, intially i was going to refit oem but decided to give the Properfekt recirc a try. Its supplied with 2x springs so i put the harder one in to suit increased boost.
Fitted, forgot to take pics but its buried in the turbo area.
Took it out for a datalog after fitting, and the recirc has indeed fixed the problem. No massive spike on pre throttle boost sensor on high rpm lift or rev limiter.
Comparing old logs vs new. 2x laptops sorts the men out from the boys 😅
Eml issue is now resolved (with extensive high speed testing yesterday, the car goes like f**k too) added bonus the recirc actually sounds pretty decent with compressor surge at low rpm and quiet at high rpm, much better than oem recirc noise. Being honest, i prefer the reliability of blanking plate but with the higher 1.5-1.6 bar boost levels on a small ish turbo, its prob a good idea having a recirc.
Anyway with that done and boxed off i got onto the next job. The underbonnet sound deadening had suffered on the corner and was a bit floppy and looked shite.
I made enquiries about buying a new one from ren but NLA, so only option was 2nd hand. Found a good used replacement in U-pull it ages ago, used trim tool to remove the push fasteners that hold it to the bonnet and it fell to bits so no good/fail. With this fail in mind when the next good one came up, i then drilled the heads off the fittings to remove it intact. I removed the fittings with trim tool sacrificing the original mat, and fitted the good used one.
Much better, im sure you will agree.
Ive been meaning to wash it for weeks and with weather changing took advantage of a dry day.
Used my Di vessel to rinse. The bodywork is unreal nick for a 15 year old car.
With this done i done some more coding to the rs monitor.
The boost gauge was still going to the top and we had adjusted it to 1800mbar assuming it was using gauge pressure, but all it showed was 1800> on full boost
Note peak reading line maxing out the bar graph.
As i had been logging with Rstuner im used to reading the data in Map absolute instead of gauge pressure. Im quite used to this due to reading standalone ecu map sensor data.
To explain very roughly how this works as it can be confusing after using gauge pressure.
1000mbar on map pressure is "absolute" - its including the vacuum which starts at 0mbar- 1000mbar. You see 1000ish mbar at sea level with engine off (atmospheric)
0mbar of map pressure = full vacuum
1000mbar of map pressure = atmospheric 0psi
2000mbar of map pressure = 15psi of boost
1000mbar gauge pressure is 1000mbar of boost above the atmospheric mark of "0mbar"
-1000mbar of gauge pressure is full vacuum
0mbar of gauge pressure = atmospheric 0mbar.
1000mbar of gauge pressure = 15psi of boost
Some ecu's work in map pressure - some ecu's work in gauge pressure depending on setup. Renaults of this era always use map absolute as above.
Anyway back to the point
My rsmonitor boost gauge seems to read in Map Absolute compared to later ones reading in gauge, there is no minus readings on mine. So it was always exceeding upper range as we needed 3000mbar to show full range of map sensor readings as peak on Rstuner is 2600mbar.
So with this in mind i adjusted the upper limit to 2800mbar to give slight headroom. Using a convertor to work decimal to hex with 1200 ofset (winging it being honest, ive just ) learned how to reverse engineer it the hex code a bit)
New code uploaded with ddt4all.
Tested and working with readings not maxing out the bar. Note peak line just under full range.
Used Rstuner to confirm readings were good when on the move. All works fine, Rs monitor reading is rounded to nearest 50 (i.e. 2500, 2550 mbar) which i might change to 10 or 1, if refresh/sample is quick enough..i think renault used 50 rounding to keep it clean.
Anyway works great. Pretty pleased with that!
Tried reading but my brain started leaking out my ears so will leave at looking at the pictures.
f**k knows what or how you've done it but well done!
Cheers mate!
I could lie and say it was easy to modify the display but i had some head scratching moments modifying the coding. Also arse nipping writing custom code incase it went wrong, i just send it and hope for the best. All worked out OK, No guts no glory:LOL:
Nice work on the RS monitor stuff. Always thought the same with mine that a lot of it wasn't that useful, especially with a tuned car
Long time no update.
250 has been used a bit this year and finally ticked over 19k😄
I give it a once over, motd etc in April and its been used a handful of times. It didnt need a clean so ive not washed it, as only driven in the dry. The brake dust/road muck was getting unacceptable so big clean yesterday.
BH snowfoam, autowheel for brake dust, 2 bucket posh wash
Rinsed and Koch Chemie spray sealant
Rinsed with di vessel and blow dryed
Mrs done the interior
Prob take it off the road for winter in next couple of months.
Great shot:
If you got rid of the grass you wouldn't need to cut it and would have room for another Renault......
The bricklayers that done the block paving also said the same, you can get 3 cars on the grass 😄
The grass is currently fucked due to a crane fly infestation so would be no loss..only downside would be cleaning the extra block. Already got 150sqm to de weed and keep ontop of.
I was thinking about seeing if i could extend the garage 4mtrs forward without too much drama. Prob be taking the piss as currently 60sqm.
