172 Cup OEM+
Where do I begin.
1. - Two months before I was due to go on another Euro Trip to Switzerland the gearbox developed a leak from the selector seal.
2. - Two weeks before leaving for Europe I decided to fit EPAS. Had it on a previous 182 and REALLY rated it and wanted it again. @KivsGarage aided in fitting it. I 'helped'.
After fitting EPAS, I had mega issues with where the boss sat on the spline and centering the steering wheel. When I took it for alignment I was being told I needed to leave the boss, but undo the 6 grub screws and move the wheel which didn't sit well with me. Much faffing later and it seems the person who I bought it off may have had the column apart, I didn't even know they came apart. Ughhhhh anyway. 4 alignments in one day and the wheel was straight, the rack was central and the boss was in the correct place. Hooraaahh! Or so I thought.
3. - The day I was leaving for Kent (staying the night there before Le Shuttle) the Clio threw up an "oil - - - -" light on the dash. No problem, I'll do a full oil and filter change on the day I'm leaving at 9am.
3.5 - I pack the car and leave for London. Driving on the motorway and the steering isn't happy. It felt like I was driving on a windy bridge and I needed to make micro adjustments to the steering to keep the wheel stable/straight. Closer I got to London, I noticed going around roundabouts, going right felt fine, turning left felt awful like no PAS. UGHHHHH!
4. - Le Shuttle is booked for 4pm. So I woke up early, checked the car over and thought I'd take it for an alignment. It wasn't quite straight. However it still didn't feel right, so I decided to pull out of the trip.
5.- As I packed the car up at my friend's in Kent, I turned the car over and saw "oil - - - -" again. I added 200ml to turn it off.
Drove home. Unpacked the car. Moved the car in to the garage and "oil - - - -". It took a other 600ml to turn the light off.
I then decided to drop the oil, (waste of adding that 600ml).
There was 3L in it. No external leaks.
5.1L + 200ml + 600ml =5.9L. So it burnt almost 3L in 400miles.
Looking at the oil that came out, it looks like grit with metal shavings in it.
So I'm glad I didn't take the Clio to Europe.
HUGE thanks to @KivsGarage for holding my hand through all of this. Been an absolute legend.
Some random photos from all the above.
Whats going on in the last photo? Getting ready to have the engine out?
Bad luck all round. Do you have a tracking sheet print out?
Tracking, I have multiple print outs. It is pointing straight. I think the column motor is faulty or the wire supplied isn't up to task.
Yeah, started to strip it down and see if I can see any signs of what led to this point. Plugs are clean. However the oil smells alot like fuel.
Oddly grateful, that this happened when it did and not at some random petrol station in France. I had a feeling the car didn't want to go on the trip, after the selector seal leak and then the epas column and then the alignment chaos.
If the Mk2 motor is faulty have you looked into fitting a mk3 epas set up instead?
This weekend @KivsGarage and I (well I watched) took the engine out and stripped most of the usable bits off the old engine on to a lower mileage 172 Engine.
Dropped the 197 cams in, fresh cambelt, dephaser and waterpump. Went to do the timing and the Cam Stud started to snap. So we stopped and called it a day and I ordered a new Cam Stud from RPD. £4 part stopped us timing it all up etc. Ahhhh well.
We didn't inspect exactly what has failed on the old engine, I'm leaving that to @KivsGarage in his spare time, as he took the engine off with him for the parts bin. Kiv also took my gearbox off to replace the selector seal as that's leaking.
The new 172 engine, I'll give it a good scrub and a lick of paint, same for the engine bay.
I also dropped the subframe to send some bits off for powdercoating.
Lots to do.
But if you thought that put me off you'd be wrong..... a few months a go I bought a cheap 182 to daily for my daily.
Glutton for punishment.
Called a "local" zinc plating place today, said "yeah drop them in". Hour drive there to be told "go get them shot blasted then we can zinc plate them". Drove an hour home. 2hrs nothing to show for it. F*cksake.
I did get the old sump off.
This sump bolts E8 pieces of s**t were an arse. However only 2 REALLY fought me.
On the phone I explained the bolts were from a 20 year old car, so I think they knew what to expect.
Pissed me off a bit wasting time like that. Didn't help traffic was a b**ch too.
Might just give them a dip in citric acid and be done with it.
I had some wheel cleaning acid I submerged all my bolts in then I filled a pot with engine oil and let them sit so they didn’t go instantly orange I mean they won’t last forever but they look good I’ll just squirt bit of clear waxoil over them when together 🤷
Update.
Had the subframe and a few other bits powdercoated.
Dipped the bolts in citric acid, followed by a dip in some bicarb of soda to neutralise the acid. The coated with Zinc Galv spray.
They all now have this finish.
Also sprayed up some engine parts.
Sourced a 197 dipstick and guide and gave that a lick of paint.
Lastly, second engine sprayed up and looking a bit better.
All coming together for a big final push.
Looking good mate, have you got any other 'while you're in there' jobs planned?
Might have mentioned it earlier but I'm having the selector seal replaced in the gearbox, it had a mild leak but the gearbox itself was great, no crunches. I was tempted to drop a diff in at the same time but funds are lacking all things given (the BG182).
Fitting a DCI rack, as I wasn't sold on the looped rack feel.
Think that's it... (he says)....
This set the engine rebuild back a few weeks.
The exhaust cam shaft stud snapped. So I had to order another, then life got in the way a bit. But we got there in the end.
Engine in
@KivsGarage in action. I did do some work I swear, but someone had to get the photos!
This was a good sight after seeing it for so long without the engine in it.
All back together
Took it for a short drive around the block, wheel alignment was wildly out, other than that was all good.
Had to get a photo of it with the 182.
Needs wheel alignment, a coolant flush as it was running water to flush through first. But it seems all good.
Huge thanks to @KivsGarage again for all his help with this, I'd be screwed otherwise.
Was a learning opportunity for me too, having never pulled an engine out before.
Just watched the vid on YouTube! Top work! Channel and views seem to be growing too which is amazing to see!
Thank you mate.
I've not advertised the YT channel here. But if people stumble on it that's cool.
As a 'youtuber' (I do cringe at that term), I've ALOT to learn. Talking (whilst thinking) to a camera is HARD. Also, remembering to film bits whilst your hands are deep in the engine bay is another struggle. All excuses, I can hope to get better. 😅
Thank you mate.
Everyday is a school day! The more you do it the easier it gets, same as everything, fair play for having a go though, hope it works out and continues to grow!
Enjoyed the Youtube vid mate and thrilled to see it come back to life!!
Cup meet up soon??
Cup meet up soon??
Thank you mate, I'm trying!
Regarding a meet, I did pencil soemthing in for October, then the engine went. Could still do something this year, maybe?
Yeah, great vid. I thought it was just me who had bad luck with his Cup :ROFLMAO:
BTW what paint did you use
Thank you mate.
For the engine I used Simonz VHT Silver. Used it in the past on other Clio engines and it lasted. Takes a while to fully dry though.
Small update.
Took the 172 Cup for a wheel alignment got it pointing straight, drove home and then went away for a week. Point being, I've not driven it much/at all.
That changed to day. Took it for a spin to local car/bike enthusiast cafe and on some local roads.
There and back, faultlessly.
I'm naturally quite nervous as I don't want it to go bang or tell me it's got the thirst for oil, again. However, so far so good.
Now, one thing I noticed driving the 172 and the 182 is the power difference.
The 182 does have a 98ron RS tuner map and that's it. The 172 has (if you've been reading this) alot more done to it.
To me, the 182 feels like it has more torque. But, the 172 is rapid as you rev it out and the redline is so high that it feels like it won't stop going.
I knew the RS2 inlet does change the torque but I didn't think I'd notice it.
TLDR; 182 more torque, 172 Cup more BHP, huge red line and the noise!
Nice video again on YouTube. I was surprised that you got the sound down so much given that you didn't actually use so much of the sound deadening material. What was the cost, as I may have missed that bit?
I'm sure most of the noise comes from the boot floor, the wheel wells and the rear quarters but did you consider the roof also? I'm guessing that the ball ache of pulling the lining down put you off but it's a really good effort to make a difference.
And yeah, "Rattles and Clios go hand in hand" is so true lol.
Had a big birthday recently and the wife surprised me with a weekend away (kid free) in a lodge in the sticks of West Wales.
As it was just the two of us the missus suggested taking the 172 Cup and choosing the scenic route.
I really got back in the grove with the Clio, giggling like a little girl on the sweeping roads. Apart from one small trip out, I've not used it that much, so this was a welcome excuse to get some more miles on it.
It has developed a knock from the front so I need to give it a but and bolt check.
I'll also be fitting the second bucket seat as I've got the BG182 for those family trips where the three of us may go out in a Clio.
The exhaust is a reproduction standard thing and keeps the sound in the cabin to a manageable level. But I hate the way it looks, in fact I dislike downturned Exhausts full stop. The idea of fitting a small single exit exhaust and cutting the bumper is in the back of my mind.
Also, a Quaife diff.
Looks lovely
Surely that backbox hangers/not fitted correctly as I'm sure you know should be tucked up behind the bumper?
Can assure you the hanger is correct. I think if anything the rod/bar welded to the box isn't where it needs to be, maybe?
Exhaust does look a little like a bollock hanging out of speedos...
What about a stealth box?
Hahahaha. Made me laugh.
I've got a KTEC stealth here, but it's too boomy. Maybe I'm getting old or what but I want a quite exhaust? Or at least an exhaust I can't hear in the cabin. Then again, it's a Clio.
I've read mixed reviews on that catback...
I'm being fussy.
@NorthloopCup fitted a blackline diff to mine when he built my box, makes a big difference to the way the car drives, they're about £400 cheaper than a quiafe too.
Really? Is the Quaife worth £400 more? Is it a fit and forget diff?
I've got a KTEC stealth on mine, I've been considering chopping the stealth tip off and just welding a straight tip on the back with a bumper cut out instead. I find with the stealth tip, it really booms up into the car which sounds great, but not for long periods of time.
Very true I have heard they can be a bit loud 🙉 I think you are right to be fussy, definitely get what you want - it seems like a crap shoot aftermarket exhaust noises. My 172 has 182 style dual exits so I will be the last person to say you can't cut the bumper. Double walled exhaust tips ftw 🤌
