Mk1 Running Problem & PAS
Car  Clio Mk1 1.4
Hiya, my 1400cc mk1 rt clio, runs really rough when its cold, its a similar story to the thread posted further down called "running lumpy" or something, except mine dies off then jerks back on the power, its as though there is a fuel shortage somewhere then it powers back on, i have used wynn's injector cleaner, that made it better, until it turned colder, now its hard work to keep the power on when its cold without it slacking off...... any ideas.
Also, can you fit a powersteering system to a non PAS clio, i know you gotta change the front axle, but can you just bolt a system on, or is it a case of fitting one that runs with a PAS engine??? if so i feel an 1800 coming on lol!
Clean the ISCV with carb cleaner, have not not a pic handy to show you, someone hopefully will have though.
Axle stays
You need to get the pump and the rack and sort an AUX belt to power it and maybe brackets depends hwos yours is setup.
1.8 etc engine is an ideal. I'd never add PAS though.
