DO 172FF'S HAVE BRAKE LOAD COMPENSATORS
I was just out for a wee blast in my "02" 172ff :) up a straight (private) road and back its about a mile or so long.
I went up and down for a blast a few times then headed home again. (Curious to see what i got in each gear :rolleyes: haha)
After a play about, i headed home and at the end of it is a juction with another road to the left(to my house), i was flying up to it (on the straight) and was still doing abot a ton so hit brakes a bit too hard and abs kicked in, the back of the car fish tailed a bit (if thats what you call it) :S
Won't be hitting them that hard again ;)
I s**t myself, maybe a bit too hefty on brakes i think at each end of straight. :S
As when i returned home (a 1/2 mile or so away)the tyres were roasting at front and warm on rear as well as all wheels, there was a wee bit of smoke coming from front pads (a few wifts)with a fair smell too :)
My question is.
Does the 172ff's abs system have a brake load compensator attached to rear brakes that could have caused this ?
When i say compensator i mean a thing that put more power to rear wheels under various conditions.
  172 ph1 ASBO SLAYER
pass, i've not seen anything on the rear axle but thats not to say there's nothing up front. tbf you probably cooked your front pads and they went off
Sib
  Clio 172 (Silver)
mine are like this - when the motorway traffic brakes hard i often feel the back end twitch
  172 ph1 ASBO SLAYER
are these cars lowered at all? 'cos that can affect load compensators 'cos they think they are loaded up
  172 ph1 ASBO SLAYER
yup may be a little glazed a few hard hits on the pedal 'll clear that tho
best way too cool pads is to drive without using them. worst thing to do is cane them then stop, especially if you then hold the brakes on for a long period or apply the handbrake, that f***s the discs 'cos they cool unevenly and can warp
best way too cool pads is to drive without using them. worst thing to do is cane them then stop, especially if you then hold the brakes on for a long period or apply the handbrake, that f**ks the discs 'cos they cool unevenly and can warp
Ah ok cheers dude.;)
That'll be why you get grooved/drilled discs, to get rid of glazed pads and let hot gases out when braking :)
I had a similar problema and it was the alignment.
I am not expert but this is what happens when I knock out my alignment.
What alloys do you have fitted?
Is it lowered at all?
Standard 172ff alloys and not lwered as i'm aware :S
Unless last owner lowered it as i haven't in the six months i've had it.
Heres are pics of my car.
Does atnyone think i looks any lower than normal ?:S
