Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Hi All. I've just been having a look under my 172 Cup. The front brake rotors have ABS rings present but obviously the car (being a cup) doesn't have ABS. Has it had incorrect discs fitted?
There not abs teeth the front abs teeth are on the driveshfat only the rear has the rings as part of the disk the Cups have the rings there (they are removable at the back disk) but they don't need them.
As i said earlier the fronts don't have teeth they look like they but there not the abs teeth for the front on the abs cars are on the driveshaft.
The rears since they use the same parts have the teeth rings in the disk they can be removed it doens't matter Renault use the stock parts they didn't remove the ring, just for the cups but you can do for weight saving if you realy wanted.
The front disk look like they have them but they don't.
The rear on cars with abs have rings fitted the CUp doesn't have ABS but they didn't delte them form the parts list to build up the brakes for simplicity so whilst there there there no need to be there both legally or for any abs braking reasons.
The MOT railure on the fact the car doens't have any braking power at the rear. Thats down to the compensator being fixed at the back and build in from new.
Apparently with the new MOT system they use now when they key in the reg obviously it knows the car and it comes up with a statement about the rear brakes basically saying they cant fail so ive been lead to believe.
The abs rings weigh sod all (^^^ take them off for weight saving lol - but i did just that for the same reason edde ) ! )
My cup does have the abs rings on the drive shafts as well, too much hassel to remove them i think.
