Which Bosh Lambert Sensor?
  172 ph1
I've got 3 numbers from their catalogue:
0 258 005 136
0 258 006 294
0 258 986 507
Which one is correct for a late ph1 172?
The Bosch website is f**king useless...
  Clio 172 Cup
no its a lamb sensor it counts how many sheep in a field for welsh people
:rasp:
  172 ph1
I was trying to be amusing, as the Lambert sensor was one of the funniest things I'd heard on here :)
Serious question though...
  172 ph1 ASBO SLAYER
just call it an oxygen sensor, saves the confusion!
does your car have 2 sensors??
if so do you want the upstream or downstream one?
cos i have a fuelparts one in stock, upstream, but tbh its only the cable lengths and plugs that are different
  172 ph1
I assume I only have one, but tbh I haven't looked. Anyway if it does have two then I want the upstream one, not the "my cat is broken" one.
It's got the old school twin cat. I don't really want to mess around changing plugs.
  172 ph1 ASBO SLAYER
the gsf one is probably a wire in jobbie not very good at all, the more joins in a wire the more the resistance increases therefore signal is altered these things operate between 0 & 500 millivolts (ish)
  172 ph1 ASBO SLAYER
if you can take out your one 22mm spanner and take the part no off it i'll be able to help with a price, there will be 2 numbers a reno one and a bosch one just jot down both if it matches one i've got in they retail for £69 + vat you can have it for £50 all in the bosch ones are £88 + and genuine are £96+ (all approx by the way(
