my mate had a problem with their speedo and was told by a garage that it was caused by the battery being detatched for so long but i dont think this is true! and i dont know how they fixed it either!
Ive removed the dash as well and the wires were all fine. the earth point was all tight.
Theres one on easy hub.Checked that but it seems fine. Does anyone know where The ABS sensor is or what it looks like?
There only two pipes to the hub one thin one the ABS wire the other the brake line just follow the ABS line.
There talking rubish.
The system uses the front left wheel sensor but it does take account of the rest of the wheels.
not poo pooing what your saying edde but how does it work on a cup then as there are no sensors at all for the ABS,
i thought it was a senor in the gear box which reads from a cog in there ?
but then again im not a mechanic but its certainly not the battery thingy.
It doesn't use ABS so has a sensor in the gearbox. All the other Mk2 speedos work off the ABS.
