WHAT WIRELESS ROUTER ?
My dad is after a wireless router so he can connect to internet with his laptop anywhere in house rather than using a Lan Cable from modem.
Does anyone know which one would be a decent for less than £100 ?
It would have to be compatible with there talk talk modem if that makes sense :S
Or would a router just replace the modem ?
After using about every ADSL modem or ADSL router, I'm convinced that this:
http://www.ebuyer.com/product/52244
... is about as good as it gets for the money. I use them in full no-nat mode with Cisco routers or firewalls behind them, I've used them doing full NAT for the network.. and nothing comes as close in terms of cost/stability.
Otherwise, you need to look at the Cisco 857w or 877w for a higher end router. :)
Yeah I have used a few different brands of routers and have always preferred a Netgear :)
Same here, I use them at work as non-Nat and at home with NAT great performing router. Probs one of the best to work with low snr aswell.
I may be sounding silly.
But what is Cisco 857w or 877w ?
And what is full nat and no-nat ?
They're high end ADSL routers.
For home use, that Netgear is about as good as it gets for the money/performance :)
im currently using a netgear setup. seems to be fine, reliable and fast. Do not buy a D-link one. ive had two and both have stopped working after a while and i had issues with it disconnecting all the time etc.
another vote for the netgear, i have the older version of the one linked above, with a separate Netgear Wireless AP & it's been working perfectly for the many years i have had it.
