those are all things u could do if u wished and would make the car a little better but u dont need them!!
as ling as u hav decent discs and pads to reduce brake fade and as u said new tyres the car is good to go!! and they are surprisingly good as standard on track too
Tell you what - I'm not saying thats incorrect but I was very surprised at how well my totally standard brakes held out at Donington the other day - not a hint of fade & they worked superbly throughout the sessions!!!
not been out on track in mine yet but have a reasonable amount of track experience and am looking forward to getting on again.
general concensus appears to be that they're well up to the job in standard trim - there are one or two on here who have racked up an impressive number of track days in theirs, seemingly without major complaint.
only modification i might consider with mine is brake fluid/hoses/front discs&pads - depends how i get on with the std kit though. the suspension and the drivetrain are apparently up to the job, although i'm a bit dubious about the engine mounts and the gear shift meself.
you're off to the 'ring then? are you taking any sneeky video footage?:evil:
Change oil + filter
Brake fluid + braided lines make sure they got life in them
trye pressures
Coolant etc..
make sure engine is in good running codition
probably lots have been mentioned already but thats what id do
