Blowing between pistons(Fred?)
T21PHY
Car  Renault clio182 TROPHY
As above really i know head gaskets go and start using water or cream stuff in the oil, hard to start and that. But what if it went between pistons?
Fred or anyone else for that matter know the signs?
Thanks
Ben
So you'd know about it. i.e run like crap, i'm only askin as when i got the car it dumped all its coolant on the first day and temp went off scale all warning lights came on. Bottom hose came off. Just wanted to know long term damage something the stealers might keep from me.
Thanks for reply.
Ben
ake it to specialist breakers in accrington 01254 386661 they'll tell you if anything's wrong
if you're lucky it'll be fine
unlucky, new headgasket and a skim
it happens sometimes - i've done a gasket change on an f7p that had blown between center pots, and a similar case on a volvo turbo engine. you diagnose by fitting your compression tester, taking a reading then removing the adjascent plug and re-test the compression. if it drops then its blowing. in severe cases you can hear the compression isn't right when you crank it :)
+1 compression test is the only way to be certain, the blow will also be visable on the gasket when taken apart
my 106 gti
So how would i know if its gone as the car seems fine. When the coolant dropped out it was 2.5 years ago do you think i would of noticed something with performance?
Thanks for the replys
trust me you would know
it would be like a tractor.
mine completley fucked the head and block.
where it had blown the 600cc gas burn holes where it jumped the cylinders
