it happens sometimes - i've done a gasket change on an f7p that had blown between center pots, and a similar case on a volvo turbo engine. you diagnose by fitting your compression tester, taking a reading then removing the adjascent plug and re-test the compression. if it drops then its blowing. in severe cases you can hear the compression isn't right when you crank it![]()
