New TBR Rev-counter for the 182
Tom
Car  i3
TBR developments have shipped me one of the new 182 Race Gauges. We plan on pricing these at £19.99 + P&P
This product will allow the 182 to feature 3 shift lights, Handy for those who easily miss things, also goes up to 11 (Thousand RPM)
Fitting pics later, its just got off the boat from the factory in North Korea.
3 shift lights is a good idea to be honest, should sell well on CS
1st light " on cam"
2nd light " VTEC just kicked in yo"
3rd light " Hi I'm Jesus"
Can I have a go at hitting 11k revs in the shed?
I will speak to Kim (head of TBR NK) and see if the new crank, cams and pistions are ready for fitting, should take 6-8 weeks as hes a bit busy with the IAEA.
Should hit 11k easy.
looks good; lightweight too i imagine.
i too would be interested in the bundle, including dash and gauge
where do i order Tom?
does this run off the coil or via the ECU/trigger wheel?
No idea, its still sealed.
The box says;
코일을 첨부하여이 제품이 발생할 수 있음을 우리가 생각 화재 TBR 바위 김 사랑
The box says;
ahh no probs then, my HIglballi is a little rusty, but i think that says
"the revolutions are calculated by a intergrated wind flote and noise sensor, this kit only works in 1st gear and the diff must have a final drive of 4:9"
Fitting kit ? How many wires ? Can you supply it with alternative bulb colours I have pink neons and would like it to match?
Ummm 3 wires I would need one of the nice guys at TBR to fit it if possible.
Would you need the car long ?
this thing mount in the dash or is it one of those that that you stick in a pod or screw into the dash?
