Homebase sell a cheap awning.
Problem solved.
You don't want to be working in direct sunlight anyhow.
Sunny up in Salisbury but I can't be bothered to do mine today.
It's officially raining lol
On it's way to you Tim!
Group buy, move to aussie?
Cheaper everything + nicer weather...
The Menz can take about 10 mins ! You really will have gone from one extreme to the other. Well lubricated would be my way of describing it.
Also work bearing in mind you need a hell of a lot less polish than with most other things when the Menzerna. Once the pad is primed you will only need one or two very small dots more polish per panel. Use to much and you will never get it to break down, when worked long enough there should be nothing hardly left to remove let alone it be a pain.
LOOOL What a crock of s**t! I shoulda really asked before I used it!
I think I used far to much!! :lolup: It wouldnt budge! Ah well I'll know for next time! Got through about half a bottle of the 250ml stuff![]()
